Hi guys,
Just a quick note to say we're working hard on fixing all reported issues and we should be able to supply an RC2 tomorrow evening. (approx 20:00 central european time, tuesday)
Yours,
Radiance
Octane Render 1.022 beta2.2 RC1 available [obsolete]
Hi !
I have been very busy these past days, and I have only tested Octane in the few last minutes , but I Encountered the vertical stripes problem (I had the hope that it was only a display bug, but images are saved like that as well), and a weird thing with memory management : the memory load bar at the right bottom of the render window doesn't work, and the available amount of memory is always zero. Each time I move the mesh node in the graph editor, the used amount of memory increases : I got up to 2048 / 0 MB (I have actually 512 MB on my graphic card). Added to that there are weird square areas in a chess pattern on some parts of my car model used for the test.
I also forgot to say that Octane refuse to exit.
Those are great news. Thanks a lot Radiance. Another big plus of octane is indeed its support.radiance wrote:Hi guys,
Yours,
Radiance
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
Can't wait, I'm on a stand still at the moment....I can't use the 2.2 rc1radiance wrote:Hi guys,
Yours,
Radiance
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Personally I'm extremely happy knowing a new version is coming out...but guys, aren't you doing a bit too much? you do not have to kill yourself....I know Siggraph is getting closer, but do not burn out!
I'm very satisfied of support and follow up by the team, I really can't complain...just don't over do...you still somewhere human
Great job guys and thank you for the hard hard hard work.
Hal.
Hal.
Core i7 990x|GTX 580 3GBram|PNY GTX275|24GB ram|Win 7 64Bit....and the wonderful Octane
Hi all,
We're nearly done, we're still working on the strange blocky shading issue,
the other tasks are done.
We're having a bit of problems fixing it so it won't be for today.
let's make it tomorrow instead.
Radiance
Radiance
You guys rock the Customer Support so hard, no worries.
Thanks Octane Team!
Thanks Octane Team!
radiance wrote:Hi all,
Radiance
CPU - i7-950 3.06 Ghz, 24GB Ram, Win7 x64, 2 display monitors, GeForce GTX 580 3GB Classified. I'm glad to say I LOVE OCTANE!
- SurfingAlien
mmm... don't know, may I have a refund?radiance wrote:Hi all,
Radiance
I'm kiddin'
thank you
MacBookPro unibody 2x2.4GHz | 4Gb | 9400M+9600GT 256Mb | OSX 10.6.8
i7 2600-K @3.4GHz | 8Gb | GTX560Ti 2Gb | Windows7x64 | Octane 1.0 b2.52
- SheepFactory
By the way can I have two different versions of octane installed on one machine or do I need to uninstall the previous version before installing a new one?
you can have all the version you pleased install, as long as they are in diferent folders, but even that is taking care of at install, cause it makes it's own folder with version number.
Right now I've got 1.21 and 1.22RC1 and run either or both at the same time testing things.
