[Unsupported] Blender plugin v1.12
yoyoz
I've opened a bug and talked with Campbell. It may take a few days for him to fix as he's pretty busy with fixing bmesh at the moment. I've documented the issue regarding UVs (this prevents all exports) and he will look at the normals stuff also.
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
steveps3
excellent work. I will have a go at turning off the normals when I get home tonight. What exactly does the options do?
(OS) Windows 7(64)
aLeXXtoR
Thank you, Lionel!! :)
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
yoyoz
steveps3 wrote:excellent work. I will have a go at turning off the normals when I get home tonight. What exactly does the options do?
I exports the normals :-)
This could be important if you want to have your normals point a given direction. Although Octane seems to accommodate well when you don't (this is default setting when you export from wavefront plugin), there may be some side effects.
On a side note, if it doesn't affect your project, you can simply don't export them at all, this will speed up the export.
It also seems the UV system is completely broken, I saw another bug report about UV layout export...
pixelrush
I think I saw a TO DO in the committers mailing list for UV prior to the bmesh merge. I don't think it is done at all yet. :roll:
Bmesh will apparently break a lot of scripts and be slower... :cry:
Octane v1.55
aLeXXtoR
pixelrush wrote:I think I saw a TO DO in the committers mailing list for UV prior to the bmesh merge. I don't think it is done at all yet. :roll:
Well, BMesh is a big feature. And it not yet in official build — they just start merging it. Such issues are appropriate.
WebSite
Showreel
Synthercat
Is this the lastest plugin for the official build or is there a newer one?
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
aLeXXtoR
Synthercat wrote:Is this the lastest plugin for the official build or is there a newer one?
Lastest is 1.16 — but it is for lastest Blender builds with BMesh only.
WebSite
Showreel
Synthercat
So as long as I use official blender I stick with 1.12?
matej
Synthercat wrote:So as long as I use official blender I stick with 1.12?
No, use 1.13 with camera fix. 1.12 exports camera upside-down (actually is fault of blender code change, not exporter).
cgmo.net
Return to “Blender”
