teknofreek wrote:Thanks for the reply Tutor. I've just received the amfeltec switch, so I'll see how that works..
Unfortunately I need to run a Wacom tablet and 3D Connexion spacenav, so maybe they're also taking some IO ( don't really know though).
I might try to remove the MSI 680 lightnings from the main MB. They are not branded ti, but maybe are hogging resources as most of this problem came about when I replaced the 660ti's with those.
Anyway thanks again.
Just a little note on riser (USB3 1X) or other splitter and clusters. I have the 3 types :
1) 1X PCIe USB3
2) 4x splitter (4 GPU) (4X PCIe)
3) Dual Cluster amfeltec (2 x 4 GPU) (4X PCIe)
The first is compatible on my 3 rig.
The second, I have big problem with my Asus P9X79 deluxe and octane V3 : freeze
The third, no pb yet.
About speed loss since octane V3 (more comminucation with host CPU and RAM), I have here some test from my scenes :
Test with an 980Ti:
- inside 16X PCIe : 7min16s
- with cluster (only the 980Ti) : 9min35
- with splitter (only the 980Ti) : 10min49
- with USB3 connected to 1X PCIe : 8min45
The scene is 4K size in PT kernel (parallel samples : 16, max tile : 32, adaptative) and V3.0.6 test4.
Render with network (slave) is better, but not test yet with the same scene and the 980Ti.
