Version 3.06-TEST4.1 (WORK IN PROGRESS BUILDS)
stefano-dear
aoktar wrote:
Yan wrote: I have the same problem. Very slow material previews. Macbook Pro 2016 with 1xBizon Box eGPU. i hope there is a fix.
Can you give me some idea?
Where's textures? How much is number of preview samples?
My textures are on my internal SSD disk, and I have another path on my NAS server for the textures of some 3d models library. Usually I have 20-30 materials...
But often it's very slow even when you change some parameter of the material.
Thank you!
Stefano
stefano-dear wrote: My textures are on my internal SSD disk, and I have another path on my NAS server for the textures of some 3d models library. Usually I have 20-30 materials...
Thank you!
Stefano
Still it's not clear for me.
Try to disable material/opengl previews and test it.
Also try with textures from project path.
Check main gpu has low priority.
Check preview/opengl samples from settings.
Terryvfx
@Stefano if your textures are in .jpg or .png when they are too big or too many it's gonna take some time for the plugin to load them, I suggest converting them to uncompressed tiffs to see if you have any gain in performance.
Terryvfx wrote:@Stefano if your textures are in .jpg or .png when they are too big or too many it's gonna take some time for the plugin to load them, I suggest converting them to uncompressed tiffs to see if you have any gain in performance.
This should not be much problem when texture caching enabled.
Terryvfx
I see, sorry I wasn't aware of this new feature but would this also be true for textures that you are loading for the first time? I mean decompressing a big texture would certainly account for some lag.
zoppo
Maybe you have some texture paths in Cinema's preferences? That can slow down materials a lot.
C4D 2025 | Win10
Cheiser
In redshift render you can use any C4D shader (including Layer system) for texture source.
Any chance we can get it in Octane?
Cheiser wrote:In redshift render you can use any C4D shader (including Layer system) for texture source.
??? It's working since long time with c4d shaders. But it's like baking a shader to images. So not a runtime calculation and not adviced. Wait until OSL version out for much better support.
Cheiser
Wow. Just found it. I was looking for C4D shader node from the list, but there is no node like this.
But then i create Layer or C4D shader inside material dropdown list - it creates Layer and "shader-name" node. Wow. WOW!
indigoGnat
rodross wrote:Thanks Ahmet for the hard work. Here's an example of the fruits of your labor.
I've rendered two images, one interior, and one not. The interior scene saw no speed-ups, at least in this scene, from adaptive sampling. However the robot render went from 4 minutes @ 4k resolution and 4k samples on PT, to 1 minute and 20 seconds with AS on.
What settings were you using for the Adaptive rendering on the interior scene? Render times?
