These are note why we write. There's a problem on previous sdk for offset of hdri. You can't never update to newer versions of plugin without fixing the offsetX number of your HDRI.miohn wrote:I also had to switch back from 3.05.3 to 3.05.1 because of that
massive difference in brightness when rendering a project made with 3.05.1.
Did not had to time to figure out what causes this!
Also rendering with PT.
regards
Mike
Version 3.05.3 (13.01.2017)
aoktar wrote:These are note why we write. There's a problem on previous sdk for offset of hdri. You can't never update to newer versions of plugin without fixing the offsetX number of your HDRI.miohn wrote:I also had to switch back from 3.05.3 to 3.05.1 because of that
regards
Mike
In my case, rotation of the Environment is not causing the brightness problem. I will keep looking to see if there is something causing the change between 3.03.3r1 and 3.05.3
- elisabettagiovi
Hi guys,
The realflow plugin issue seems like it's back with the new release.
It's rendering normaly in the octane window, but when the render is launched in picture viewer it crashes no matter what on the second frame of animation.
Please consider this when making the next update (I hope very soon).
Cheers
Cheers
Please report it to Realflow guys too? Because these crashes was not about my plugin.elisabettagiovi wrote:Hi guys,
Cheers
Hi LBau,
yes sure, from R18.028 or superior.
I'm at middle of some revisions on my side. And started to work with new sdk. There's lot of addons and takes some time to complete all. But i might think to make pre-test release without all. Just with adaptive-sampling and a few more.grain wrote:Hi Ahmet, when do you think you'll have a 3.06 out?
Adaptive sampling looks sexy..
and please add a mini tutorial how to set adaptive sampling in c4d (to speed up rendering)
PS
my question about Realflow particles still open. It is possible or not?
PS
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
