OctaneRender 3 for Modo [OBSOLETE]
Uhlhorn
Ah, thanks. :-)
(I did’t see it)
Dmi3ryd
When I start octane plugin error is:
______
Started logging on 22.08.16 15:36:55
OctaneRender 3.03.3 (3030003)
Unexpected response format:
Modo 902 SP3
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
______
Can you pls PM abstrax regarding this issue and he will help you.
Following is a Windows installer pre-release of the next version, which fixes a few of the issues raised recently.
3.3.3.113 (pre-release)
- Fixed crash when setting the Modo Blur Length to 0
- Fixed issue where of the Modo camera DOF effect is disabled the plugin would not disable dof rendering
- Resolved error where a Volume Medium NodeGraph node was not being connected to the Volume geometry
- Resolve crash caused by "Ghost" Instance items
https://render.otoy.com/customerdownloa ... _64bit.exe
MrFurious
Looks great Paul thanks very much.
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
MrFurious
I found a repeatable crash with the latest Octane plugin 3.3.3.113.901. When adding a Modo render output, Modo will crash. You can do this on a blank scene and it will crash. After I uninstall the Octane plugin it will work.
Dino.
Dino Inglese
CG Artist
Melbourne Australia
Dmi3ryd
MrFurious I am trying to reproduce your error. launched octane and added render output. No crashes.
MrFurious
Thanks Dmi3ryd what version of Modo are you using? (I'm using Modo 902 SP3) and I assume you're using the latest test build of the octane plugin. If I simply launch Modo, even before activating Octane, and try to add an Ambient Occlusion render output Modo will crash. Very strange..... I'm was hoping this could be replicated by someone else, will have to do more testing.
EDIT:
Looks like my config file was somehow corrupted. I reverted to an older config file and it now works.
Dino Inglese
CG Artist
Melbourne Australia
Dmi3ryd
I feel very uncomfortable when the Octane Nodegraph window closes automatically when you press the other area.
Paul is it possible to fix this ?
smicha
When 'live geometry update' is on and when I want to tick 'load cage' in Octane Mesh -> Modo crashes.
Return to “Foundry Modo”
