OctaneRender® for 3ds max® v2.10
Karba
mykola1985 wrote:Image
Yes, I don't have wall displacement texture, only floor. Could you send it to me?
mykola1985
what???? how could i miss that??? ok!
you have probably 2 missing textures. both belong to the wall (displacement + bump)
i will send you via email in 7z
update. sent both textures for the wall to [email protected]
p.s. my gpu is already overclocked by default (factory overclock i guess). maybe i should lower the clock speed and the voltage?
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
Karba
mykola1985 wrote:what???? how could i miss that??? ok!
I got the texture, will try again.
What you can try to do:
1) try 2.04 with overclocked gpu
2) try 2.10 without overclocking.
mykola1985
Ok will do without overclock first! i will push gpu clock from 941 to something like 904 and will let you know
00Ghz
If you got freezes and driver resets GPU OC could very well be the culprit. I had issues myself with plugins and standalone when OC-ed too much.
HDRI Editor for Blender : Your own HDRI Studio at an affordable price.
https://gum.co/HDRIEditor
mykola1985
00Ghz wrote:If you got freezes and driver resets GPU OC could very well be the culprit. I had issues myself with plugins and standalone when OC-ed too much.
my GPU is not overclocked by ME, it has factory overclock: ASUS GTX 780 STRIX 6GB OC edition
however thank you for your advice ;)
00Ghz
oh well maybe you just lost the silicon lottery ;)
mykola1985
lowering the clock value of my GPU doesn't change anything.... it freezes as before but this time after 7 frames. yesterday it was after 68 frames
i always get this in error log:
CUDA error 999 on device 0: An unknown internal error occured.
- failed to deallocate device memory
- could not get memory info
- failed to unload module
boris
just a guess:
have you tried modifying power options?
http://www.sevenforums.com/tutorials/77 ... hange.html
go for high performance.
there is also a pci-express setting.
set everything NOT to throttle down.
little chance, but I would give it a try.
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
mykola1985
boris wrote:just a guess:
already done that before!
btw thanx! ;)
