Cinema4D version 2021.1 RC1-R3 (Older 2021.1) 10.08.2021
VVG
karu wrote:
VVG wrote:
karu wrote: The workaround works for me; could you confirm you're using the following settings?
yes, settings coorrect.
I will send you a test scene
I've looked at the scene and this is unrelated to the original problem; that can indeed be addressed with the workaround I suggested.
My guess is that the desire here is to save an image from the live viewer containing the rendered image composited over the background. This is not possible at the moment because the save functionality is provided by Octane core, but the concept of a "background" is an aspect of C4D. For this to work the plugin would need to ask Octane to save the imager to a buffer, and then composite the buffer over the background before saving it, rather than asking Octane to save the image itself.
If you save a picture via LV (LDR / sRGB) - it does not work. If rendered through PV Cinema4d - it works (LDR / sRGB)
thanks
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
LOVEXMEDIA
aoktar wrote:
iwinadCAX wrote:Is there any adaptation for cinema 4D R25?
Is it out for all of you?
It is indeed. I am excited to get some new renders in R25!
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
BCres
Yes, on C4D R25, though not in any real hurry. Over half of my other plugs haven't been updated either.
Still could use it to test 2021.1 while I keep working with 2020.2.5 on S24 for projects.
BCres wrote:Yes, on C4D R25, though not in any real hurry. Over half of my other plugs haven't been updated either.
It's available for 2021.1 windows version, but having build issues yet on MAC.
SSmolak
aoktar wrote: It's available for 2021.1 windows version, but having build issues yet on MAC.
That's great but where exactly download it ? On the first page the last is S24
I mean I have it, not published yet
VVG
Do not forget to fix the UI color for dark theme
VVG wrote: Do not forget to fix the UI color for dark theme
Ok sir!
