Cinema4D version 2020.2-RC5 (Release candicate) 23.12.2020
Antoncromas
Does no one else have issue of images being saved at a wrong gamma from the picture viewer?
Antoncromas wrote:Does no one else have issue of images being saved at a wrong gamma from the picture viewer?
What would be great if you give a better explanation! What's your reference to believe that gamma wrong? What's colorspace in render settings?
omardex
In my experience windows photos app is not a good way to test a color profile in a picture, use photoshop or similar sofware, depending of your file type and settings in the render settings the image should be correct in your compositing app.
possibly the photos app is assigning a profile to you picture thats why is looking like that.
check for tonemaped or linear combination of settings in the render settings of c4d.
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
Antoncromas
its the same in Photoshop, any file format. All my old scenes have this issue which were rendered with no problem before.
Simple scene attached.
Untitled 1.rar
(91.62 KiB) Downloaded 405 times
Antoncromas wrote:its the same in Photoshop, any file format. All my old scenes have this issue which were rendered with no problem before.
I think you're talking about saving denoised beauty from render passes, correct?
Antoncromas
No no. When the image rendered from the picture viewer its being saved with a wrong gamma. I had to go through the photoshop and invert gamma to .45 to match the image that is shown on the picture viewer.
RobertoFauceglia
I am having the same exact issue. Every scene that I render is being saved at a wrong gamma, not what is scene during the render or in the IPR. I did not have this issue before the update, all my scenes rendered beautiful.
Antoncromas wrote: No no. When the image rendered from the picture viewer its being saved with a wrong gamma. I had to go through the photoshop and invert gamma to .45 to match the image that is shown on the picture viewer.
OK detected the issue. It's a case when save passes with c4d save formats when you select sRGB colorspace. It still assumes saved images are linear. I'm fixing this part for RC6 builds
RobertoFauceglia wrote:I am having the same exact issue. Every scene that I render is being saved at a wrong gamma, not what is scene during the render or in the IPR. I did not have this issue before the update, all my scenes rendered beautiful.
Please read my answer one post before. I had to revise a lot of parts in this area(color management).
lanklaf
@aoktar
BUG: Channel Inverter node and Color Correction node.
Channel inverter node does not work for normals.
For example, if I want to invert the green channel of the normal - first I have to split the channels and then use the inverter node on the green channel.
If I use the inverter of the color correction node after separation, it will not work either, only the Invert node works.
Channel Inverter node: X
Invert node: (OK)
Color Correction node: X
System:
i7 8700K / RTX 2020 / 16GB RAM
