Performance comparsion of various GTX cards (including oc)
justix
shikakka wrote:Tested the benchmark scene with the GTX 670 (Gigabyte GV-N670OC-2GD, factory overclocked)today .
I tested with Octane 2.58c (Kepler test build) and Nvidia 301.42 drivers; the test system had a Core i7 3770 3.4GHz, and 32GB RAM at 1600MHz.
The results:
DirectLighting 01:04 minutes 9.35 Ms/sec
Pathtracing 03:38 minutes 2.63 Ms/sec
PMC 04:41 minutes 2.05 Ms/sec
You mean the Octane Benchamark by Legrenzi? 16000s/p? DL completed in 1:04 Minutes? well that is WAY fast off my GTX470..OK my Rig is a bit dated but we are talking GPU cores and my GTX470 | cCuda Driver 4.20 Cuda Runtime 4.0 Direct Light complete the render in 15 minutes..something wrong?
edit: maybe I was stupid? benchmark could be the one posted here at 1000s/p? in that case is about a minute and 3.30 PT
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
marcio_max
The results:
These are the numbers for a GTX680 (from EVGA, not overclocked) with NVIDIA driver 302.59.
Benchmark trench, all kernels have alpha shadows switched off.
DirectLighting: ∙ 9.18 Ms/sec
Pathtracing: ∙ ∙ ∙ 2.67 Ms/sec
PMC: ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ 2.02 Ms/sec
What is the clock speed on your GTX 670?
Roeland
Same result in my GTX 470
| Windows 8 Pro x64 | Octane for 3ds Max/Standalone | i7 860 | 12GB RAM | 1x EVGA GTX 670 4GB / 2x EVGA GTX 670 2GB | Cooler Master HAF 932 |
adrencg
I have the 580, so will the 590 double my render speed?
Ryzen 5950x
128GB Ram
RTX 3070 x 3
Phantom107
Great topic, thanks for the hard work!
I was looking for another GPU for the desktop, and this really helped comparing the ones within budget. I ended up with a 2nd hand GTX570 for just 180 euros. Which is a steal for a student like me!
On a side note, I am constantly amazed at the insane PCs you guys have. Haven't seen it like that anywhere else.
petergazo
Phantom107 wrote:Great topic, thanks for the hard work!
I took a secondhand gtx580 1.5GB for 200 euros :) Now waiting for another bargain like that.
i5-2500k | 16GB ram | gtx460 2GB (display) + GTX580 1.5GB | Win7 pro x64 | v1.0 beta 3.00b | http://www.behance.net/petergazo
renmaxhb
Who tested gtx480 with 512sp?
gueoct
With my GTX 580 3GB, the benchmark scene renders:
3,65 Ms/sec. Not the 4,41 as described at the beginnig of this thread...
How can that be ????
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
t_3
gueoct wrote:With my GTX 580 3GB, the benchmark scene renders:
the chart reads 4.14, apart from that you also need to read the footnotes (there's a reason, why exactly that line is grayed out ;)), and take into consideration, that the chart is over a year old, done with octane 2.48b.
since i now own 580s, i can tell you that - at standard clock, but with the latest nvida driver (what can make a difference) - 2.48b renders this scene with 4.02ms/sec, whereas 2.59 does 3.98ms/sec. so your 3.65ms/sec are not that much off, but imo it should be faster...
The obvious is that which is never seen until someone expresses it simply
smicha
Octane Render works about 5% faster under newest nVidia driver 306.23. Do you also have such speed up?
t_3
smicha wrote:Octane Render works about 5% faster under newest nVidia driver 306.23. Do you also have such speed up?
on what card?!?
funny enough, when i posted the above, i used 2.59 + 301.42 and had around 4ms/s;
after installing the new driver i only had ~3.85ms/s - switching back to 301.42 - still 3.85ms/s :?:
maybe, that is the way how nvida is going to make the 6xx cards faster than the 5xx ones ;)
hey, i want my 0.15ms/s back... rebooting...
