OCTANE BENCHMARK: Submit performance scores for your rig!
Tugpsx
Did a benchmark with the GTX480 it was a 11.27Ms/Sec and with then added back the GT240 is that correct 12.36 with both cards on DL 3.35 on PT 2.27 PCM are these any good.
karanis
3x zotac 580amp and 1 msi 680 => Pathtracing : 14.91Ms/sec
Asus rampage IV extreme mobo, win7 64, i7 3930k @4.0, 1600Mhz sys memory, cosmos II (no liquid cooling)
Using EVGA PrecisionX for fan control (all fans set to max) and 680`s power target is set to 120% and +100MHz overclock (could not overclock 580s).
The system also works as a heater for my room, yay, lower gas fees.
System takes about 4.8-4.9 ampere in 220 volts, which is about 1000+ watts of continuous electric consumption.
Acoustic performance is ... u know... about 4000 rpm / gpu fan and 1800-2000 rpm for sys fans. It`s loud but a Megadeth video can suppress this.
Win7 64 & Slackware 14 64 | 3x Zotac 580 amp & 1x MSI 680 | i7 3930K @4.8 | 32 GB | Asus rampage extreme IV
igen
I forgot the detail .... 2 zotac gtx 690 ~ 44Ms/sec use pathtracing
rendercamp
virtual photography & 3d animation
asus maximus extreme VI :: i7 3770k :: 16 Gb Ram :: 4 GTX 690 4 Gb :: win7 64 bit
glimpse
igen wrote:I forgot the detail .... 2 zotac gtx 690 ~ 44Ms/sec use pathtracing
Are You sure? =) Any printscreen to base Your performance claim?..
igen
Sure, I was do printscreen from 1-4 cuda ..... I will post soon after I come back from other town
rendercamp
badmilk69
EVGA 670 SC 4GB
Octane 1.0
2.9 ms/sec
Not bad, not great but 4GB!
Screen Shot 2012-12-05 at 9.41.04 PM.png (12.13 KiB) Viewed 9346 times
i7 2600, 16 GB RAM, 2x Evga 670 SC 4gb, dual boot win7/osxML, 2 SSDs, 3 HDs.
karanis
Hi igen,
Can you please confirm that ?
It looks impossibble, may there be somthing you are missing ??? ...
I could get about 22Ms/sec with 1 zotac gtx 690 using DIRECTLIGHTING...
I could get about 6.5 Ms/sec with 1 zotac gtx 690 using PATHTRACING...
Are there any uberclocks that you do ?
Waiting impatiently...
BorisGoreta
GTX 680 4GB
Octane 1.0
11.7 Ms/sec direct
3.01 Ms/sec path
badmilk69
BorisGoreta wrote:GTX 680 4GB
Octane 1.0
11.7 Ms/sec direct
3.01 Ms/sec path
Dude my 670 is too close to that mark and cost just 440usd.
cfrank78
I get about 1.93 with my gtx 560TI and about 2.27 with my gtx 660 TI MSI.
Both together reach 4.5 MS/sec!
What the fu...? I read This thread and saw some reach 4 or 5 with the GTX 560 only!
I use version 1.0 final Release with the newest Drivers and Cuda 5!
Is there something wrong with my System?
Kind regards Chris!
