OctaneRender V4 XB3
vijay
funk wrote:
vijay_thirukonda wrote:
funk wrote:Black diffuse materials with a scattering node plugged into medium are much brighter when denoised
Could you please send me the scene?
Here is a simplified scene
left: no denoise
right: denoised
Thank you for the scene.
Notiusweb
I just exported a 720 frame sequence through Batch Render with Denoiser on, and as the process ran each frame appeared in the viewport as being denoised.
But here is the beautiful part - the saved images were not denoised at all.
Full noise.
AWESOME :|
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
coilbook
Re: OctaneRender V4 XB3
vijay
Notiusweb wrote:I just exported a 720 frame sequence through Batch Render with Denoiser on, and as the process ran each frame appeared in the viewport as being denoised.
Full noise.
AWESOME :|
Did you enable "save the denoised beauty instead of the main beauty pass" checkbox? Just tested it, seems working as expected.
Notiusweb
Full noise.
AWESOME :|
No...Ugh! :oops:
It's right there....I guess in the case of the Batch-Render script, it needs that separate instruction...
Sun of a Beach..... :x
Plugs: Enterprise
Trage
Excellent work.
I use a 4k monitor and the font appears with me as 8 point.
Will it be possible to change the interface or font size in the Linux version?
greetings
roeland
For the standalone version you can override the UI size with a command line parameter, probably --dpi 192 in your case. 96 is the usual value for low DPI displays.
Trage
@roeland » many thanks, my eyes rejoice now! :lol:
I still wish you little bugs and a lot of fun at work.
Notiusweb
Would it be possible to split the denoiser in half, for bright pixels and dark, and then you could denoise shadow and bright areas separately?
Denoising shadow requires more denoising blend, but many times I wish that I could leave some noise in the brighter areas becasue then it looks a little too blurred.
I can make it look great, just wondering if there would be some mechanism that could be employed to do this in a later version....
Oh...but without making it slower :roll: :oops: .
Plugs: Enterprise
fedoragfx
When is the public release of V4 planned to be released? I take it that it depends a lot on the plugin developers to finish their part before that can happen but do you have a date estimate?
Windows 10 | GTX 980 Ti + GTX 1060 3GB | Xeon W5590 x2 | 32gb DDR3 1333mhz
