Except the AI denoiser, all others should work on the PMC kernel as well.treddie wrote:Do the 4.0 improvements work for PMC?
Hello World: OctaneRender 4 is here
- Elvissuperstar007
- Contact:
OSL planet atmosphere shader +11111 ?
Yes, it supports Kepler cards. Either you should be using PMC kernel or the denoiser failed to denoise, in that case, there should be an error message in the log window.mikinik wrote:vijay_thirukonda, hi. denoise not work on kepler? I just have a black screen instead of denoise pass.
It happens without loading a scene:vijay_thirukonda wrote:could you please send me the scene.funk wrote:
I tried opening a log window then activating denoiser. Nothing comes up because the application crashes before it has a chance to log anything.
1. Start octane 4
2. Add a render target and click on it to start rendering
3. Enable imager > enable denoising
RESULT: After a couple of seconds octane crashes
I have saved this and attached it too, just in case.
- Attachments
- crash.ocs
- (52.92 KiB) Downloaded 276 times
vijay_thirukonda , thanks, now I get it, he doesn't have enough free memory.
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
- Elvissuperstar007
- Contact:
Ecosistem orbx 3ds max to stand to 3ds max ? 3ds max to cinema 4d ?
So, I tested the octane on several machines.
Previously, I updated the drivers to the latest version.
1. Start octane 4
2. RMK > material > diffuse
3. Go to core engine and select PT
4. Start render
5. Enable imager > enable denoising
After a couple of seconds octane crashes.
this happens on all machines.
1. win8.1 2x nVIDIA 1080ti - crash
2. win 7 1x asus 1070 - crash
3. win 10 1x zotac gtx960 - crash
4. win 10 2x nVIDIA 1080ti - crash
5. win 10 2x asus 1070 - crash
when i try to enable denoising with custom scene via load ORBX same thing happens.
1. Start octane 4
4. Start render
Could you please a quick test to eliminate out of memory error?. Set the resolution to 4 x 4(denoiser usage will be less than 10 MB) in the film settings node and then enable denoiser. We do handle when denoiser can't allocate memory, so ideally it shouldn't be crashing but just logs an error message.divasoft wrote:So, I tested the octane on several machines.
1. Start octane 4
4. Start render
- Rikk The Gaijin
RIP Maya users..........
