Version 3.04.5-R2 (05.12.2016)-Previous stable
Proxell wrote:Does Octane render support scaling TurbulenceFD Container or not?
Cos Octane render wrong scale or position.
Here is an image:
https://gyazo.com/5aecbd21773fa7005cb57badcfe1d22a
Default redner make this redner correct.
It's default render and results are calculated by itself of TFD. Here i'm doing a convertion between different logics.
See this test version: viewtopic.php?f=86&t=57222#p294161
It doesn't support non-uniform scaling.
Proxell
Here is an image:
Thx for answer so fast.
It seems that test version works. But when I scale down — density parameter stop to work.
Proxell wrote: Thx for answer so fast.
what does mean? It's not related with scale.
Proxell
Sorry, we have 2 volumes inside each other. And when you set volume step length lower then inside volume it will render with settings of outside volume. :shock:
teeshiiddo
I'm also getting the wrong position with VDB files between the viewport and LV. Its was always a little off, but this update has made it worse "- reversed z-axis orientation for VDB volumes"
The VDB has been created in 3DsMax with FumeFX.
Asus X99 10G WS | Windows 10.0 | 6x GTX 1080 Ti + 2x 2080Ti | i7-6850K CPU @ 3.60GHz | 32GB RAM
teeshiiddo wrote:I'm also getting the wrong position with VDB files between the viewport and LV. Its was always a little off, but this update has made it worse "- reversed z-axis orientation for VDB volumes"
Which version are you mentioning? I put a test build did you see?
Making it reverse that's turning back from a mistake. It was reverse for openvdb volumes and also for houdini generated vdbs.
As common side note:
When someone talk about problems please let send some sample scenes. Quality of plugin depends to user feedback quality. You'll not just help me also to others and yourself.
rafg
Using TFD Containers this new test build is working correctly for me, scaling up, scaling down, increasing/decreasing density. I scale in Object mode just fyi.
lideborg
Might not be anything but I'm currently using R17 I can only get octane to appear inside c4d when I'm using the R16.cdl64. When using any of the other ones it's just not in the render settings.
teeshiiddo
I haven't tried the test build. I need VR Version, Win is there one?
Current version OR C4D 3.04.3
lideborg wrote:Might not be anything but I'm currently using R17 I can only get octane to appear inside c4d when I'm using the R16.cdl64. When using any of the other ones it's just not in the render settings.
You need to update c4d as noted in release notes.
