OctaneRender 3 for Poser (Windows/OSX) [OBSOLETE]
Erick
face_off wrote:Following is a pre-release of the plugin compiled with Octane 3.06 TEST 4, which will hopefully resolve the issues people have had with Normal maps in previous Octane 3.06 releases.
3.6.3.82 pre-release
- Compiled with Octane 3.06 TEST 4
- Fixed issue where the Scatter mesh type was not working. If you change a figure/prop from Scatter or Proxy or Mesh, the scene will refresh if the Viewport is open
https://render.otoy.com/customerdownloa ... _Win64.exe
Could it be, that it's still broken?
I couldn't get it to work, atm. The scattered mesh did not appear.
I used Posers hi-res square as the mesh to be scattered over the ground plane.
After switching back from Node Type "Scatter" to "Mesh" (with the mentioned refresh of the Viewport) the mesh (hi-res square) showed up again.
Erick
I have to revise my post from above.
By creating a new transform file, scattering works well and as expected.
It's just that previous generated (in older versions generated) transform files do not work properly.
wimvdb
I have been working a few days with this new version and it seems to work fine now. No more gpu crashes or other problems.
Good work!
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
I have updated installer at the top of this thread with:
3.6.5.81 (23-Apr-2017)
- Compiled with Octane 3.06. See viewtopic.php?f=24&t=60014 for details
- Added status window to show the progress when the plugin is loading the camera animation track into Octane when the Camera Motion Blur checkbox is ticked
RGUS
face_off wrote:I have updated installer at the top of this thread with:
Thanks Paul, but why is the download file called "OctaneRender_for_Poser_3_4_4_79_Win64"... have you run out of numbers and have to reuse earlier ones?
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Thanks for reporting this problem. I have put the correct filename in now. Pls re-download the installer.
Erick
New version!
Yay, thanks Paul :D
wimvdb
Thanks Paul!
xorex65
Thanks for the update Paul ! :D
OneShotos
I noticed that the latest OSX version of 3.6.5.81 has Subscription in the file name. The Previous version do not. Name mistake or is this the Subscription version?
Return to “Poser”
