OctaneRender® for 3ds max® v2.11.1a
smereces
Thank you Karba! keep up the amazing work on the plungin
Merêces Arch & Design 3D Visualizations
Website: http://www.sergiomereces.com
3dgeeks
This version takes over all the all GPU. I have 3 GPUs and when i switch one off through the Octane 3dmax panel, I still cant work in any other application. This was not the case in earlier 2.0x versions.
WhaleHunter
3dgeeks wrote:This version takes over all the all GPU. I have 3 GPUs and when i switch one off through the Octane 3dmax panel, I still cant work in any other application. This was not the case in earlier 2.0x versions.
I have seen this since 2.1x versions as well - PC's with disabled GPU for working and netrendering to the alternate cards. kills performance. totally. prior to 2.1x was working as expected.
Spdo
Hi everyone;
Last months i alwyas used 3ds max 2015 sp5 on saturday my friend told me change to your 3ds max version to 2014 and fix your all problems
so he is right today i return 3ds max 2014 sp5 and everythings is fine
I wrote a lot problems on this topic but today everything changed and clear thank you for my friend Derya.
recommended return 3ds max 2014 or earlier.
HHbomb
HHbomb wrote:
"Fixed performance regression in PMC kernel introduced with version 2.11"
I know that you work hard and there it tones of things to do, but it would be great that a max version with PMC with a better performance can be done before major release. Thanks.
this build should contain this fix.
I don't think so, PCM is 3x lower in rate than PT
Spdo
This is my latest problem on octane stand alone and 3ds max plugin
I changed everything when i was read over the google youtube etc but i couldn't fix.
Can anyone help me how to fix this prbolem
I have a deadline on Friday but i can't render.
Please help me.
mikinik
Spdo may be it overheating
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
Spdo
mikinik wrote:Spdo may be it overheating
no miknik the all cars tempurate max 45 degree now
i always look the evga software to control fan speed e.t.c.
akira
Or maybe your power supply is not capable of 4 x 780ti (needs 1500W at least), or you're using a UPS that is not allowing high power consumption?
glimpse
Spdo wrote:This is my latest problem on octane stand alone and 3ds max plugin..
when You get that blue screen? las time I had such problems (crashing) just after opening OctaneRender window from F10..was related to power supply.. (just a though for You, don't say it's the only reason, but it was my case..)
