OctaneRender® for 3ds max® v1.50a
Angelos
bicket wrote:
render setup / common / every Nth Frame should be 1 not 4
you're so smart))
of course everything was set up correctly
https://dl.dropboxusercontent.com/u/100 ... .18.09.png
mbetke
You render 1-50 but only every 4th frame as far as I read your settings. Set it to one and render again.
PURE3D Visualisierungen
rfox
I don't know if there any new tricks on this version,but the sun light won't get through the glass surface therefore no shading area behind the glass, I tried both materials (glossy mat with opaque 0.1 & specular mat with fake shadow checked). no luck :|
3x GTX Titan - Win7 Pro x64 - Intel i7-3930K - ASUS Rampage IV Formula-X79
Karba
rfox wrote:I don't know if there any new tricks on this version,but the sun light won't get through the glass surface therefore no shading area behind the glass, I tried both materials (glossy mat with opaque 0.1 & specular mat with fake shadow checked). no luck :|
Please show your render.
mykola1985
Hi Karba,
just wanted to ask a question.
Can I solve this without blurring the image? I mean better AntiAliasing
url immagine
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
Proupin
This is common with overblown exposure, those pixels (and more importantly, the subpixels) have higher values than (1,1,1). Vray for instance has an option to clamp the output, that along sub-pixel mapping, will anti-alias correctly, but you lose all information beyond (1,1,1), which really sucks. You can only try to either limit overexposing, or try bloom so those areas bleed out.
mykola1985
thanx for the reply! ;)
vfxman83
Hi Kabra;
How can fix this problem?
Thank you.
rfox
Hi Karba,
I re-installed the program again, and appeared work fine. Thank you
rogerteddy
I had a scene, where I used Pflow Particles. It was working in maxtane 1.2 but now preview window doesn´t work anymore. It takes hours to open and then it remains at sanple 1 forever, even closing the window is not possible, max crashes. When I delete the Pflow Particles everything works good.
best regards
rog
Return to “Autodesk 3Ds Max”
