i assume you have folders listed in the sub menu, so... is "browse disk" working for the same folder? can you test it with some pretty basic folder like i.e. c:\test?AlfaseeD wrote:Looks like I have some problem with the
-Browse recent
The window don't appear.
OcDS 1.2.120.34xx - BUG REPORTS
Moderator: BK
Tried out templating. It works as advertised (it's fantastic) but it's a little wonky.
First time I tried it, nothing happened when I dragged the template material over the current material. After restarting DAZ, it worked perfectly the first time. Second time I applied the material DAZ crashed with "DAZStudio.exe caused ACCESS_VIOLATION at 0033:00000000004B4C43". Report attached.
But MAN that's a good tool, it's going to save sooo much time!
- Attachments
- DAZStudio_error_report_140212-213120.zip
- (57.73 KiB) Downloaded 264 times
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
yes, unfortunately; had some testing myself yesterday (usually there is far too little time to do so), and also found out about this - under certain circumstances; did you have the viewport open/octane rendering when applying the template? it seems to be save as long octane is not rendering, at least i had this impression...DrHemulen wrote:Tried out templating. It works as advertised (it's fantastic) but it's a little wonky.
Nope this was without the render window open, both times.
Geografting is totally broken in the new update for me, it doesn't hide the old polys anymore, not even in the viewport (Genesis2F/Genesis2Fgenitals). That worked in the 1.2 befor the update. Works fine in the DAZ public beta i have installed in parallel.
Loading files generated with older versions of the plugin still works for some reson, but "clean" DAZ files from the beta doesn't.
(Not trying to be mister negative here, I really love the direction you are taking)
with "even in the viewport" you mean the daz viewport? that would be pretty strange, as of course the plugin only reads information from daz elements and doesn't alter them (apart a few places like aspect ratio settings)...DrHemulen wrote:Nope this was without the render window open, both times.
this seems to work, um, crash rather reliably...Jazbee wrote:Can't really find a way to reproduce the bug 100%, but the first few times it worked like this:
1. Create a cube primitive
2. Change its material to Mix (mat1:glossy, mat2:mix) while attempting to change mat2 to mix, DS crashes
Hope this helps
Agreed something a little strange with geograft on G2F - I found a work round by right-clicking on the base figure and selecting 'Create all 28 as new materials >, Auto materials'.DrHemulen wrote:Nope this was without the render window open, both times.
mh. i have added an exception for that cases; should be gone with the next update...SimonJM wrote:The Opacity setting of -1 seems to be a common thread if a non-standard shader is used (an additional example would be the 'G2F Bot Armor' items).
