Does it work now?Angelos wrote:Karba wrote: oops! i'm sorry! just now i saw that 3.0 is deactivated on my machine.
OctaneRender® for 3ds max® v1.0 beta 3.00[Test]
Works now and it faster than 2.58 in 3dsmax 2013Karba wrote:Does it work now?Angelos wrote:Karba wrote: oops! i'm sorry! just now i saw that 3.0 is deactivated on my machine.
My render test scene shows 1.42 instead of 4 minutes
but when i hit close 3dsmax it hangs down
I will post a new version soon. But it will be still a test version. It require some time to be a bugs free.Angelos wrote:
Instancing support have forced me to reorganize most parts of the plugin, so it was expected that some new bugs would be introduced.
А ссылочку на известные проблемы можно, не нашел.
Я как-то уже писал о проблеме переполнения оперативной памяти, тогда эта проблему исправили. По моему проблема вернулась в эту версию плагина.
(Также очень часто вылетает 3d max при закрытии или обновлении вьюпорта)
http://render.otoy.com/forum/viewtopic.php?f=27&t=22530pyrnik wrote:А ссылочку на известные проблемы можно, не нашел.
guys use google translate if you can't write in englishpyrnik wrote:А ссылочку на известные проблемы можно, не нашел.
We're testing the product, not just obschaemsya.Chem more if I write about any issue, using an interpreter, the meaning may be distorted and loss. Can someone too lazy to use a translator. I suggest you tie a forum automatic translation of the Russian, so if I write in the text box text when sending to the server so that it automatically translated.
Так лучше?
						Так лучше?
Problem is If you do mistake in some words google translator can't translate it properly.pyrnik wrote:We're testing the product, not just obschaemsya.Chem more if I write about any issue, using an interpreter, the meaning may be distorted and loss. Can someone too lazy to use a translator. I suggest you tie a forum automatic translation of the Russian, so if I write in the text box text when sending to the server so that it automatically translated.
Так лучше?
We have a special topic.
http://render.otoy.com/forum/viewforum.php?f=39
You can use Russian there. I read it sometimes.
