Octane Render 1.022 beta2.2 RC2 available [obsolete]
mib2berlin
I'am sorry.
To think like a german ingenieur with less knowledge about English it is hard to explain.
But i think i got you.
Man this was difficult, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
andrian
Texture gamma input seems not working.
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
radiance
andrian wrote:Texture gamma input seems not working.
noted, we'll check it out.
Radiance
andrian
radiance wrote:
andrian wrote:I am getting a little slow down with RC2, it gives me 2.48 samples vs 2.95 samples on beta 2.1 on a simple scene. All manually imported and textured, its a simple interior room with no textures, lit by sun/sky, on GTX 480.
are you sure everything is configured identically ?
the scene file format is not compatible, so you need to recreate it, and you might have differences.
also keep in mind that this version needs to do a bit more work than 2.1,
it has recursive textures, which is quite a bit of additional/complex code to run through on each ray.
In fact, i was expecting an bigger slowdown, quite happy with the results.
I think some scenes might be a bit slower, and others a bit faster depending on how you configure your mats.
Radiance
This slow down happens on a scene with no texture at all and diffuse shaders only. Light comes from HDRI but I try sun/sky and default light - pure white and its the same..a little bit slower
CGsociety gallery
My portfolio
Web site
SheepFactory
Any idea what might be causing the loss of realtime interactivity on my end? 2.1 runs silkys mooth.
http://www.alimation.ca
Win 7 64 bit
Gtx 275
i7 920
6gb ram
Driver version: 197.13
radiance
SheepFactory wrote:Any idea what might be causing the loss of realtime interactivity on my end? 2.1 runs silkys mooth.
you mean the sunsky updates ?
it's because 2.2 is a major rewrite of large areas of the render kernel for multi-gpu.
there are some multi-threading synchronization issues that cause the delay in updating the sunsky currently,
which we're fixing.
Radiance
cgbeige
radiance wrote:
cgbeige wrote:ah, ok. It's in pathtracing with filtering off.
and directlighting is ok ?
Radiance
weird - tested with a new scene and it's fine in both methods. I can't test with the scene that was troublesome before because I can't open scenes I saved with dual GPUs on OS X (but you know about this).
One thing that has never worked but I forgot to mention: if you change the resolution of the image, it resets your subsampling settings.
ltchest
with the benchmark scene, im getting 16 M/sec using a GTX 480 + 2 x GTX 280. Thats awesome :)
Win7 64bit. i7 3930K 4.2Ghz.32GbRam. GTX670(4Gb)+2xGTX580(3Gb) | 3xGTX780(3Gb). 337.88. 1200W. (+ 5 x i7 2600 nodes).
SheepFactory
radiance wrote:
which we're fixing.
Radiance
You guys rock. Thank you for the update.
Win 7 64 bit
Gtx 275
i7 920
6gb ram
face
It is a good idea to have the reported errors as a list in a forum?
Maybe one under "Commercial Product News & Releases" and a mirrored one under " Plugin Discussion/Support"
They should have only read access.
So the user can read the reported bugs and know, his one is reported before.
face
http://vimeo.com/user2509578
