NEW: Octane X - is finally here! [MEGA FAQ THREAD]
Vitaliyromanov
Does anyone have any luck running on a Radeon 580X? My iMac freezes on rendering
TheBloke
bepeg4d wrote:Hi,
AMD Big Navi 6800/6900 XT support in Apple Metal driver should be already available in Mac Os 11.3 beta 3, so they should be supported in the upcoming 11.3 stable update.
ciao Beppe
Hi Beppe, I was wondering if you could explain further about what you've heard regarding 6800/6900 support? I have installed 11.3 beta 3 but my 6900XT is still not recognised - I have to boot with a second GPU installed to see the GUI, and the 6900XT is not listed as an available Metal GPU. Thanks.
Jedi_blade
Weezer wrote:It's been a long wait, but finally I have Octane X rocking all three GPUs in my Mac Pro! Thanks for the year's Enterprise subscription (was easy to get and install). Everything seems to be working just fine!
Which three are you running.
Mac Pro (2019)
3.2 GHz 16-Core Intel Xeon W
96 GB 2933 MHz DDR4
Two AMD Radeon Pro Vega II 32 GB
After Burner
Pixege
I confirm there is a problem with Octane X® (Mac Pro) Enterprise for Cinema 4D® PR8.
When rendering the animation, a watermark overlays the render passes after a while. Sometimes it does this after 5 frames and sometimes after 50. Main Render has no watermark, but the animation stops there and Octane render the same frames.
MacBook Pro 16" | AMD Radeon Pro 5500M 8 GB | 2,3 GHz Intel Core i9 | 64 GB RAM + eGPU Razer Core X | Asus ROG Strix RX 5700 XT OC
Weezer
The RX580X that came with the MP, plus two Sapphire RX5700XTs. It all works well, but I do find the 8GB VRAM quite limiting.
joenyc
Pixege wrote:I confirm there is a problem with Octane X® (Mac Pro) Enterprise for Cinema 4D® PR8.
I also saw this randomly when rendering from Houdini on PR8. Had to kill the render and start over. It only happened once out of the many renders I fired off yesterday.
Mac Pro (2019), 2.7 GHz 24-Core, 384GB RAM, AMD Radeon Pro W5700X | Houdini
Rainbow-3D
bepeg4d wrote:Hi Gianluca,
can you share some logs about “ rectangular areas with different luminosity”?
It could be related to almost finished system RAM.
If you render at 2000x1500 it works, correct?
The frame buffer is handled in RAM in Octane.
ciao Beppe
Hello Beppe,
upgraded the mac pro to bigsur. Same problem with PR8, changed nothing (mac pro 2019 Radeon pro 5700X)
I attach a little part of the picture, sorry, I can't show more. For now my test show that the problem isn't the big resolution (it was only a coincidence: in low resolution the problem was in white areas so I didn't saw it).
It seems to be the adaptive sampling. If I turn off it, all works good. But if on, there are areas more or less light. These areas are the same "rendering blocks" of the picture (I don't know how call them, you can see when the picture is rendered, it is divided in square areas, more big is the image, more areas there are).
Same scene on Windows+RTX2080 hasn't problems.
For now I do my work without adaptive sampling, but I hope to can use it again soon.
Thank you
Bye
Gianluca
AS problem.jpg (21.26 KiB) Viewed 132873 times
Win 7 x64 | Asus P8P67-M - i72600K | 16 GB RAM | 1 x nVidia RTX 2800
Win 11 | i7 13700K | 64 GB RAM | 1 x nVidia RTX 4090
filipg
I'm very excited to get started with Octane Render on my Mac!
BUT.... the PR7 Prime for Cinema 4D R23 doesn't work at all at my Macbook Pro with Intel running Big Sur 11.2.3. When I try to create a new Octane material (doesn't matter which one) the preview is just pitch black (sometimes it looks something like a glitch). Then when I try to start the renderer, Cinema 4D just freezes and I need to force-quit. This happens every single time. Please help! Maybe Octane isn't supposed to run on a Macbook Pro without eGPU or AMD card? I read that @cjadams had some similiar issues back in this thread, don't know if they got resolved?
@ TheBloke: we have been informed by Apple that 11.3 beta 3 has the support for Big Navi GPUs, but I cannot find a Big Navi GPU here in Italy for directly testing it, I’m sorry.
If you had to add another GPU to start the Mac, it seems that the support is still not ready :roll:
@ Pixege: yes, after 3 hours of rendering, the Demo mode starts automatically, I have already reported it ti the core team.
@ Gianluca: Thanks for the report, it seems related to Navi GPU, please share a screenshot from Kernel, Camera Imager and Devices panels thanks.
ciao Beppe
reddog
Hi, I'm new on this forum.
I've downloaded OctaneX from AppStore and run it on MacBook Pro 13" M1.
Octane run very good. My question it's about Octane X prime and DCC plugins. On M1 processors plug-in for C4D and Blender seems not work.
Cinema plug-in crash Cinema4D R21 and 23 demo, Blender server don't start.
There's something i do wrong or plugins haven't been updated yet?
TankYou
