I've updated the version to R3. Don't forget to delete unused dlls otherwise you may get loading problems.
Enjoy it!
Cinema 4D version 4.02.1-R3 (Obsolete stable)
- neiwei845458454
The octane render v4 can not render the TFD smoke in Cinema 4D R20. Can you fix this?
Hi, Black Shadow render pass is broken again and gives very bad/unusable results.
- donantonio99
Hello.
I am getting some strange problem - when I render image sequence its getting slower with each frame as showed in attached image. I stop it, continue rendering - the first frame in a row is ok and the nexts are slower and slower..
Its going from 4 mins per frame up to 40-50 mins.
Cinema R18, tryed different drivers, now on 417.71
1080ti + 1060
Any ideas?
1080ti + 1060
Any ideas?
You can see more details in render log. See CONSOLE window and post all text here.donantonio99 wrote:Hello.
1080ti + 1060
Any ideas?
I could not solve the problem with R15. It's always crashing. I'll put it if I can sort the problem.TonyBoy wrote:Ahmet, in the event you do manage a C4D 15 version, will you post it here?
- donantonio99
Where is it? I see Octane Log, its empty, only these 2 linesYou can see more details in render log. See CONSOLE window and post all text here.
Started logging on 22.02.19 11:02:28
OctaneRender Studio 4.02.1 (4020100)
PS - I run GPU-Z, and it says PerfCap Vrel with the blue filling.. I guess its something about that..
R3 seems to have fixed the crashing on startup. Woohoo! Thanks!
Also, is Vectron supported on the Octane Subscription (Studio) build this release? While checking out the new features, I noticed I don't have a Vectron button in the Objects tab in the LV.
Thanks for all you do!
