Version 3.08.5-R3 (V3 stable) 24.10.2018
thanulee
Heya, I keep getting cuda 700 and cuda 201 errors on some scenes. What are those errors are exactly? Im using 980tis here so i was wondering if they are a bit old. ty
sreinger
Cant found the Matte function in Texture/Diffuse -> Common.
Where is it now ?
Hi thanulee,
CUDA error 700 is Nvidia drivers related, or timeout related.
Which Nvidia drivers have you installed, and have you installed Standalone to change TdrDelay?
ciao Beppe
thanulee
bepeg4d wrote:Hi thanulee,
ciao Beppe
I have tested with many drivers no luck. Same error 700 happens in v4 version as well. Atm im at 417.35
I have standalone installed. What is TdrDelay that needs to be changed ? I used to mess with it with substance painter instructions, but can u please resend me how to and what values do i need to set? thanks a lot
do you have a X99, or X299 motherboard with 3/4x GPUs?
If yes, please have a look at this solution:
viewtopic.php?f=9&t=68650
About TdrDelay, what happens is that the Windows system instantly disable the GPU drivers, if it does not receive a signal after some seconds.
By default the TdrDelay is set to 2s, i.e. if one kernel call takes more than 2s, Windows kills the driver.
If you install the Standalone via installer, we change some Windows registry to better work with GPU Rendering.
To change the timeout, either run the Standalone installer or manually set the TdrDelay key to something like 10s or so. See here:
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
In the Standalone installer we set these values:
WriteRegDWORD HKLM "SYSTEM\CurrentControlSet\Control\GraphicsDrivers" TdrLevel 3
WriteRegDWORD HKLM "SYSTEM\CurrentControlSet\Control\GraphicsDrivers" TdrDelay 10jh
Some Win 10 users have set the TdrDelay at 60, to solve their stability issues with CUDA.
ciao Beppe
thanulee
No i have only 2 gpus. Ur link is not working. I always install standalone.
So i change those values from inside standalone or direct from registry? thanks
niestudio
Thanulee,
Try this link. Looks like the one before had some extra characters on it.
https://msdn.microsoft.com/en-us/librar ... e/ff569918
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
