[Unsupported] Blender plugin v1.xx - Code
grenzfrequence
If i disable "Import render in Blender", then i get an error as follows:
Octane plug-in v1.10 on 2.57.1.36339 : OBJ export time: 8.398 secs
Octane plug-in v1.10 on 2.57.1.36339 : MTL file: "/home/goatrance/Data/tmp/Eurothing.mtl.temp"
Octane plug-in v1.10 on 2.57.1.36339 : Processing <Glas_klar>
Octane plug-in v1.10 on 2.57.1.36339 : Source image : "/home/goatrance/Desktop/g/pepnettextur.jpg"
Octane plug-in v1.10 on 2.57.1.36339 : Copying file "/home/goatrance/Desktop/g/pepnettextur.jpg" to "/home/goatrance/Data/tmp/pepnettextur.jpg"
Traceback (most recent call last):
File "/home/goatrance/Apps/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/engine.py", line 99, in render
write_mtl(mtlTemp, mtl_list, scene, octane_render.export_copy_images)
File "/home/goatrance/Apps/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/export.py", line 241, in write_mtl
filename = copy_image(mtex.texture.image)
File "/home/goatrance/Apps/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/export.py", line 151, in copy_image
copy_file(fn_full,fn_dest)
File "/home/goatrance/Apps/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/utils.py", line 113, in copy_file
file = open(source, 'rb')
IOError: [Errno 2] No such file or directory: '/home/goatrance/Desktop/g/pepnettextur.jpg'
location:/home/goatrance/Apps/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/modules/bpy/ops.py:179
Error: Something wrong happened, please check console logs
Where is the bug?
Greatings...
ubuntu 11.04, cuda 4.0, octane v1 2.48c, exporter from Lionel 1.1.0, blender 2.58, nvidia Geforce GTX 285, graphic driver 275.21
grenzfrequence
Hi, i found another problem in animation button of exporter:
Exporter stops between 2nd or 8th rendered frame. How can i solve this problem? I want to render 250 frames.
Thanks in advanced,
Stephan.
steveps3
Are you sure that the directory /home/geotrance exists because both errors seem to relate to missing files. Could this be a project that you copied from another system or maybe an old project that you are revisiting after some tidying of your system?
(OS) Windows 7(64)
grenzfrequence
Hi, the directories exists. But in this case i found the error: the texture was not existing, but there was an entry in the blender file. I don't know how this can be. But after erasing the entry this error haven't occured again. Therefore this problem is solved.
Therefore i only have the problem with the animation. Why stops the exporter to continue render the next frame? I entered Frame Settings as follows: Start: 1, End: 250, Step:1, FPS:24
Therefore it should render until Frame 250. Actual it renders only until frame 2 or 8 after this it stops rendering. What could be the problem?
I am really happy about this exporter because it works well and gives us good error messages to be able to find out problems. Many thanks. If we solve the animation problem then i would be very happy because i have to create an important animation the next days. Would be nice if we could solve the problem.
Thank you in advanced,
Stephan.
grenzfrequence
i tried another render without animation: it works.
The same makes problems in the first frame, i press animation. The log is as follows (the last entries shows the error messages:
Octane plug-in v1.10 on 2.57.1.36339 : Fixed name <Glas klar.003> to <Glas_klar.003>
Octane plug-in v1.10 on 2.57.1.36339 : Processed <tellerrand7segments> in 13.160 secs
Octane plug-in v1.10 on 2.57.1.36339 : OBJ export time: 13.160 secs
Octane plug-in v1.10 on 2.57.1.36339 : Processing <Glas_klar.003>
Octane plug-in v1.10 on 2.57.1.36339 : Processing <blauthemenfeld2>
Octane plug-in v1.10 on 2.57.1.36339 : Processing <gelbthemenfeld2>
Octane plug-in v1.10 on 2.57.1.36339 : Processing <grnthemenfeld2>
Octane plug-in v1.10 on 2.57.1.36339 : Processing <lilathemenfeld2>
Octane plug-in v1.10 on 2.57.1.36339 : Processing <orangethemenfeld2>
Octane plug-in v1.10 on 2.57.1.36339 : Processing <pinkthemenfeld2>
Octane plug-in v1.10 on 2.57.1.36339 : Processing <rotthemenfeld2>
Octane plug-in v1.10 on 2.57.1.36339 : MTL export time: 0.000s
Octane plug-in v1.10 on 2.57.1.36339 : Using camera : <Camera.Camera>
Octane plug-in v1.10 on 2.57.1.36339 : Using Depth of Field from : Camera
Octane plug-in v1.10 on 2.57.1.36339 : Using DoF from blender camera: 0.000000 * unitSize
Octane plug-in v1.10 on 2.57.1.36339 : Camera position: x 24.732452 y 18.522865 z 46.825329
Octane plug-in v1.10 on 2.57.1.36339 : Camera target: x 22.735185 y 18.997821 z 43.430635
Octane plug-in v1.10 on 2.57.1.36339 : Camera up: x 1.040686 y 3.827491 z -0.076779
Octane plug-in v1.10 on 2.57.1.36339 : Project file already exists
Octane plug-in v1.10 on 2.57.1.36339 : Resolution set to 1522 x 1035 at 50%
Octane plug-in v1.10 on 2.57.1.36339 : Samples per image: 32
Octane plug-in v1.10 on 2.57.1.36339 : Launching Octane: ['/home/goatrance/Apps/Octane/octane', '-m', 'Eurothing.obj', '--cam-lensshift-right', '0.000000', '--cam-lensshift-up', '0.000000', '--cam-fov', '49.134342', '--cam-pos-x', '24.732452', '--cam-pos-y', '18.522865', '--cam-pos-z', '46.825329', '--cam-target-x', '22.735185', '--cam-target-y', '18.997821', '--cam-target-z', '43.430635', '--cam-up-x', '1.040686', '--cam-up-y', '3.827491', '--cam-up-z', '-0.076779', '--film-width', '761', '--film-height', '517', '-e', '-q', '--output-png', '/home/goatrance/Data/tmp/Eurothing_000001.png', '-s', '32', '-r', '/home/goatrance/Data/tmp/Eurothing.obj', '/home/goatrance/Data/tmp/Eurothing.ocs']
Octane plug-in v1.10 on 2.57.1.36339 : Exporting frame #2
Octane plug-in v1.10 on 2.57.1.36339 : Begin OBJ/MTL export
File "/home/goatrance/Apps/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/engine.py", line 96, in render
obj_list = obj_export(scene, scene.frame_current)
File "/home/goatrance/Apps/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/export.py", line 36, in obj_export
objects = bpy.context.selected_objects
AttributeError: 'Context' object has no attribute 'selected_objects'
What is the difference between non animation and animation? The render scene is the same. How can i reach animation renders?
Greatings,
Stephan.
yoyoz
Hi guys, I'm sorry I'm awfully busy at the moment with very little time for debugging the script.
However, here are some answers:
@ SamCameron: Sam, I've not been able to reproduce the issue, single frame render doesn't reset start frame to 1 when I try. Can you describe your workflow?
@ eMirage: putting specularity to 0 should switch to diffuse, but also remember that materials are imported into Octane only if they're new. Once the material exists in Octane, it is not updated anymore. Otherwise you can switch to 'ocs writes' but this has some risks.
@ eMirage: the way the exporter gets the material info from Blender doesn't allow to know if it's a native or linked one. However, if linked materials are the same with same name theres no issue. On the other hand, if you have something too generic such as 'Wood' which refers to different setups in your libraries, then you're in trouble.
@ grenzfrequence: the image files will be copied if the option is checked in the 'export' subpanel. You're obviously missing some files here.
@ grenzfrequence: please ensure your material names and paths have no space in them until I can test the recent improvements made in Octane recently. This will ensure everything works fine and clean the logs
@ grenzfrequence: there's no reason the exporter stops at some frame. Do you have something in the logs or is it because of the error below?
@ grenzfrequence: the "AttributeError: 'Context' object has no attribute 'selected_objects'" sounds like an API change in blender and I must take some time this WE to check.
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
ephdot
Thanks Lionel. That's great work. It's very clean and interfaces very nicely.
BTW - if you guys need the support of an additional developer let me know. I've been developing software since the mid 80's and would not mind contributing towards a good cause such as Octane.
Regards,
Dan
AMD-1100T 6 core, GTX-590 & GTX-480 1.5GB, 16GB 1600MHz RAM, 1TB WD 6GB/s, Win7 64bit, Blender 2.68a for Octane 2.2, Octane 1.20, Blender/Octane Server 2.2
kirk
Just tried Blender exporter (in r36339) . Love it instantly. I had a few things not working although: gamma settings for textures and turbidity. Looks like when it comes to Octane it completely ignore whatever I set there in Blender. Those both things are very useful and I often tweak them in Octane. It's pity they are not working.
Q6600, 5GB ram, GF9800gt-1gb, 3dsMax 2008 , Blender , Zbrush, Messiah 3d v5, Terragen 2, Vue 6 Infinity
kivig
I have problem alike to grenzfrequence. When I try to render fly animation it renders the first frame and on the second one gives an error:
File "/home/k/Desktop/untitledfolder/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/engine.py", line 356, in render
safe_rename(objTemp,objFile)
File "/home/k/Desktop/untitledfolder/blender-2.57b-linux-glibc27-x86_64/2.57/scripts/addons/octanerender/utils.py", line 125, in safe_rename
os.rename(src,dst)
OSError: [Errno 2] No such file or directory
This happens both on Windows and Ubuntu.
There's no spaces in path and output file does exists. Also there's no textures in the scene.
Also I noticed that on each new rendering it gives a message box with result of previous not current rendering. This doesn't seems to affect anything but if I cancel a rendering then start a new one it says "Rendering aborted by user".
Blender 2.57b, script 1.09d.
Otherwise the exporter works great! Thanks!
http://www.visnevskis.com
Vista64/Ubuntu, GTX470/580
chesshorse
Hi all,
I've got some problems with material exporting using 1.09d script, everything was working fine until i added to my model texture with UV coordinates. Below you can find error log:
File "C:\Users\Victor\AppData\Roaming\Blender Foundation\Blender\2.57\scripts\addons\octanerender\engine.py", line 99, in render
File "C:\Users\Victor\AppData\Roaming\Blender Foundation\Blender\2.57\scripts\addons\octanerender\export.py", line 234, in write_mtl
if mtex and mtex.texture.type == 'IMAGE':
AttributeError: 'NoneType' object has no attribute 'type'
location:C:\Users\Victor\AppData\Roaming\Blender Foundation\Blender\2.57\scripts\modules\bpy\ops.py:179
Any ideas how to fix that?
Regards,
Victor
Win7 64 HP | i5-750 | GTX 670 2GB | 8GB
Return to “Blender”
