Titan Z is not overHeating, it just keeps itself under predefined temperature target (as part of a plan for Boost 2 technology).asher wrote:Z do overheat. One fan for two two gpus. ..
what i mean is that if you have one pwr box ok, but stacked? no way, unless you watercool of course.
Titan Z however on render times drops it's speed from almost 1050MHz to 700MHz+ while TitanBlack drops not so much - from the same starting point to somewhat 800-900MHz (depending on airflow). Both Z & Black are tested in the same case (I have print screens of the my desktop now).
reference 770,780(TI), Titan(Black), 970 & 980 has single fan too..asher wrote:The average 780 or 980 has 3 fans per gpu.
only non reference coolers has 2-3 fans..-this is not perfect solution, considering the fact all the heat is circulating inside the case (in multi GPU, let's say 4 GPUrigs, non reference design coolers with those 3fans perform worse than reference design cooler with single fan, throwing heat out of the case).
So, fans are nothing to do with more efficient cooling in multi GPU environment - that's not what they were designed for in the first place - representatives from companies like ASUS do acknowledge this that reference coolers work better in 4way configurations, not long ago seen video with JJ talking about that =)
bending PCB is a marketing trick to sell You a piece of worthless metal for 10-30 dollars - it has little to no effect to GPU. The only benefit is when Your OCed ram sits on the other side of GPU - then backplate acts as a giant heat-spreader.asher wrote: GPU PCBs tend also to bend from heating and cooling ( on and off computer ) unless there is a backplate. The board gets bent, soldering points get damaged.
However (again) in multi GPU configurations, especially with non reference designed coolers (2-3fans) those backplates obstruct airflow & make more damage that giving something good - as temperatures rises too much because of insufficient airflow..
so let's get back to the topic, TitanZ is not overheating, it keeps itself under control. If You want to run it's GPUs on the higher clock speeds get more airflow into case, raise fans speed & lift the temperature target (it will get more noisy, but You keep higher performance).
Or go water-cooling, leaving noice behind & enjoy high clock rates =)
