Testing Beta 0.42 (OBSOLETE VERSION)
WellDone
But this new version is 64-bit only?
I have Win7 32bit. :cry:
Thanks.
WellDone wrote:But this new version is 64-bit only?
Thanks.
I'll publish a never version soon
Druzic
Hi Aoktar,
How is rendering in Octane with the picture viewer is supposed to work with this version? I am trying to render several passes separately but its taking waaay too long... I must have done something wrong. :roll:
Druzic wrote:Hi Aoktar,
yes sure, something is needed to be adjusted. If you enabled global illumination, ambient oclusion, etc. you'll slow down standart rendering. Because when activate multipass,
octane will allow to work of standart renderer. Standart renderer will produce some passes which are not available for octane render.
Also check octane info channel samples. If this is very high so render will take long time.
Druzic
Ok Thanks Man. Also I am trying to do the beauty pass in Octane. So I select it as Renderer, Go to overwrite, check enable, select kernel type and max samples...correct? Do I need to turn everything else off separately?
I'm going to post last version (Beta 0.49)
please check, also i'm posting some new videos about rendering, etc.
Druzic
Great!! Thanks again.
Druzic wrote:Great!! Thanks again.
follow video tutorial for that, it's a little sample but will give much clue
