OctaneRender® for Poser beta - build 1.11u [OBSOLETE]
Hi VirginieC
I'm staying for now on the 1.11u because of other compatibilities reasons.
I don't think 1.13 should cause you any compatibility issues - however 1.11u is pretty robust, so no problem staying with it.
Yesterday, I exported a material in a folder, then I moved the folder elsewhere. Just after, when I tried exporting another material, poser crashed just when I right clicked to export. It was probably because the pluggin did not find anymore the folder where it was supposed to export. Not a big problem, but there may be a little code to add in order for the pluggin to come back to the "initial pluggin folder" if the actual folder does not exist anymore. Note I think it is the reason, but I'm not 100% sure of it
Did you happen to get a copy of the python exception this raised?
VirginieC
face_off wrote:Hi VirginieC
First point : I think I need Octane 1.11 for working is DAZ octane pluggin, but I'm not sure of it, so since all poser and Daz pluggin work pretty fine with octane 1.11, I preferred not to touch anything and let everything, octane and pluggins, in 1.11.
Second point : It was an instant crash, I've even not had time to see if a python exception was shown, so the answer is no.
Last point : I'm really happy with your actual pluggin, not perfect yet, but efficient when we get used to it :D
You don't need to run the same version across all your plugins - you can run 1.10 Standalone, 1.11 DazStudio and 1.13 Poser - they won't interfere with each other.
VirginieC
OK, thanks for the tip!!! It was something I was wondering and I did not dare to try!
Return to “Poser”
