yeah, and thanks a lot for making themcgbeige wrote:nice to see that my icons made it into this build. You guys move quickly
Radiance
have you installed the whole xcode package yet ?mnemonicmethod wrote:X11 installed and same problem...![]()
I think I will install snowleopard and give it a try !!!! because I don't see other solution for the moment ...
niceWhichway wrote:I can now confirm that missing drivers were my problem. CUDA 3.0 Notebook Developer Drivers required for 8000M series devices. RC1 now working on both my platforms.
Whichway
have you tried placing it between brackets ? eg "/path/to/some file/file.obj" ?cgbeige wrote:I can't get command line rendering to work. At first it tripped on the space in the path even though there was an escape character before it in the Terminal and then it just failed to load the mesh, saying it wasn't usable.
X11 is not Xcode.mnemonicmethod wrote:yes !!!!! I've used the original installation CD that came with the computer and installed the X11 application ...
@echo offcgbeige wrote:I can't get command line rendering to work. At first it tripped on the space in the path even though there was an escape character before it in the Terminal and then it just failed to load the mesh, saying it wasn't usable.
