MLT working - 9000 series or higher only
pixym
I have read somewhere in the forum this will cost about 1200 dollars. :shock:
EDIT: héhé, I did not missed, see here:
http://www.cubix.com/content/cubix-offe ... ane-render
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Krisonrik
pixym wrote:I have read somewhere in the forum this will cost about 1200 dollars. :shock:
Yeah, see that's the part I don't get. I'll take GPU-X over new Fermi card anyday of the week.
Dual Lindenhurst single core Xeon 3.6Ghz with Hyperthreads, 8GB DDR-2 ECC, Geforce GTX 260
Dual Xeon 5680 3.2Ghz with Hyperthreads, 24GB DDR-3 ECC, Quadro 4800 & GTX 480
cgbeige
GPU rendering really takes over your machine a lot more than just rendering on the CPU in the background so a dedicated render box couldn't hurt. I won't be buying a machine just for Octane but if you did GPU rendering all day, it's probably the way to go. A headless Linux box and a command line render, ideally (no waste on screen drawing).
gristle
Haha, you need to enter the second best image then!! Wow, how to guess what that might be huh.
Win 10. Threadripper 1920X 32gb Ram GTX 1080Ti GTX 980Ti 2xGTX 780
http://ajdesignstudio.co.nz/
Krisonrik
Yeah, quite tricky. You got a suck a little, but not too much. You got to be good, but not the best. Wow, talking about anal. hahaha
radiance
cgbeige wrote:GPU rendering really takes over your machine a lot more than just rendering on the CPU in the background so a dedicated render box couldn't hurt. I won't be buying a machine just for Octane but if you did GPU rendering all day, it's probably the way to go. A headless Linux box and a command line render, ideally (no waste on screen drawing).
This is easily remedied with a 2nd card/
Using a 2nd card for octane render leaves your machine %100 responsive for other work, you won't even notice it.
It will be even better than a CPU based one, as you will also have most of your CPU still available for other tasks.
Radiance
pixym
Hi all,
Rad., Could you please tell us something about MLT progress?
thwak
Based on his previous statements, MLT is waiting for the multi-GPU coding to be done (which is in the next beta release). So the beta release after that should have the MLT implementation.
Ubuntu 9.10 x64 | GTS 240 | 260.19.44 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb| Blender 2.56a/latest Yoyoz plugin
WinXP32 | GTS 240 | 266.58 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb | Blender 2.56a/latest Yoyoz plugin
radiance
yes,
we had to redo the multi-gpu using a different technique, so we launched 2.1 without it,
moved multi-gpu to the upcoming 2.2, and moved MLT to the 2.3 after that.
currently we're dug deep into the multi-gpu, which is nearly done.
then we break our heads over finishing MLT. :)
Radiance
pixym
Thank for the fast reply Rad ;)
