OctaneRender 3 for Modo [OBSOLETE]
I have updated the TEST build installers at the top of this thread with:
3.08.0.131
- Compiled with Octane 3.08
I expect these will become the next STABLE build unless there are issues found in the next few days.
I have updated the links at the top of this thread to migrated release 3.08.0.131 through to the current STABLE build.
Hesekiel2517
Thank you for the new Build!
Is it already possible to use the osl cameras in Modo? Thanks in advance
I have updated the STABLE installers at the top of this thread with:
3.08.1.132
- Compiled with Octane 3.08.1
- Fixed crash when rendering a Front Projection with no camera assigned
- Fixed issue (introduced in 3.08.0.128) where Image map powers were being set to 0 when creating Octane Overrides
- Fixed crash on OSX when loading an OBJ file. This requires Modo12.1v1 or later
This is not currently possible, but should be doable in the future.
Hesekiel2517
Would it be possible to enhance the nodegraph function in modo to get Standalone Features into modo?
Now it is possible to build shaders with a nodegraph. But it would be even nicer if it wasn't limited to that.
Thanks in advance!
What specific features would you like pls?
Tharso
The big problem with octane for Modo is the mesh loading time, in octane for maya the loading time is about 2 to 4 times faster depending the scenes with a lot of high poly meshs.
Could this be improved?
Can you provide load time comparisons of the exact same scene in Modo and C4D pls?
Tharso
Hi Paul.. Its not C4d its Maya, I did some tests last year for you. You need to try for yourself to see the difference, try a scene with 4k and 8k images and about 7 million polys maybe.
You said last year that was problem with modo and to compare fbx export from modo and Maya. I did it too and it not a huge difference. My last tests I did with modo 3.08 and Maya 3.08.
Return to “Foundry Modo”
