OctaneRender® for 3ds max® v2020.1-RC2 - 10.06 TEST
paride4331
coilbook wrote:Hi Paride,
this version splits screen into 4 parts usually visible when default background is behind
rtx enabled creates split lines and different color
And it renders slower when using RTX. That's why when AI Light is on or off with RTX on it also creates different look and brightness
Hi Coilbook,
RC3 will fix many issues with network render too.
Regards
Paride
samsue
Requeset;
- share vram for rtx 2080 ti
- multisubtexture
- update manual (it's a shame the current)
Bugs (or not)
- vertexdisplacement: quickly consumes all available memory, until it freezes the system. (It can be a simple plan)
It is only possible to use it by creating objects with a very dense mesh and using the bump functionality.
- anable displacemente: dont work
coilbook
Hi Coilbook,
Regards
Paride
Thank you. Strange part that this was done without using slaves. One master that has 4 2080tis and one titan as a display card
Rik
Something up with Octane daylight?
What does this lot from the log mean?
Tried to access pin via an invalid ID P_SUN_INTENSITY (514)
Tried to access null node pin
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFC6C61EE0)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFFC6C61EE0)
Tried to access pin via an invalid ID P_REFLECTION (145)
