OctaneRender V4 XB3
Notiusweb
haze wrote:
Notiusweb wrote:Q - Without denoiser - Is Octane V4 measurably faster than Octane V3?
1 - If YES, why the heck even bother with development on V3?
2 - if NO, what the heck!?
:twisted:
PS - heck
We are working on speed in two ways:
1. increasing the number of samples that arrive for tonemapping in the same delta time
2. increasing the quality of those samples in the same time
Our focus currently is #2, meaning that in general in V4, you don't need as many samples for the same level of noise/error (actually that means that the MS/sec measurement as speed becomes less important)
With XB4 there will be some more improvements, and you should be able to see a good improvement across most of your scenes.
That sounds very cool. I know that Tonemapping is high-cost item for the GPU, in early V3 testing it was a cause of crashes for cards running on a 1x PCIE connection, whereas an 8 or 16x connection could handle the cost better.
(Abstrax gave us the tonemapper checkbox to selectively exclude and include GPUs those GPUs which were connected 1x vs 8 or 16x, which resolved crashes)
Not sure if this is applicable, but will be interested to see if it whams the selected-for-tonemapping card harder due to what sounds like a higher compressed #samples charged per delta-time unit...but if it runs faster, really we won't care! :D
So coming is the V4 of V4!
Congratulations to the team for the job thus far.
And also good work to the users for always pushing the product forward. A lot of other forums fuss, but no muss.
This has more muss than fuss, and by muss I mean 'muscle', as in power.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
coilbook
please check 3ds max octane 4 and itoo forest denoising freezes
enricocerica
Tried the last Octane Blender Plugin version, it crashes after starting rendering of a single cube. Tried several times with the same issue, once with windows dump.
Windows 10, NVidia drivers : 398.11
Failed devices:
GeForce GTX 1070(device 0), error message: "CUDA error 719 on device 0: unspecified launch failure -> failed to create link"
GeForce GTX 1070(device 1), error message: "CUDA error 719 on device 1: unspecified launch failure -> failed to create link"
GeForce GTX 1070(device 2), error message: "CUDA error 719 on device 2: unspecified launch failure -> failed to create link"
GeForce GTX 780(device 3), error message: "CUDA error 719 on device 3: unspecified launch failure -> failed to create link"
Last Octane engine log entries:
device 1: failed to create OSL compile context:
device 1: failed to compile module 0
device 3: failed to create OSL compile context:
device 3: failed to compile module 0
device 2: failed to create OSL compile context:
device 2: failed to compile module 0
device 0: failed to create OSL compile context:
device 0: failed to compile module 0
http://www.myline.be
Greg
I'm going echo the requests for edge rounding. Edge rounding is **absolutely critical** for both CAD rendering and baking down game assets. Two areas (especially products rendering) that are probably very important to OTOY. The current implementation is not something that works well or is (to be honest) very often usable for professional product rendering. I do a TON of this stuff - Octane is so very good in this area with the huge...glaring...exception of rounded edges. Take a look at V-Ray..or MODO...and bump this up the priority list if possible.
best,
Greg
CEO Sabertooth Productions
Co-Founder Pixel Fondue
bartosh44
I would like to ask about same as Greg above. I`ve read somwere on this forum some kind of statement that new edge shader will be implementen on 3.09. I`m also wait for that feature much. I hope it will be same quality as Modo rounded shader is. With possibility unifying seperate mesh shells (a`la booleans).
I use Octane present edge round shader but is good only for third plan objects. I also think that is critical feature becouse it saves geometry (subd or heavy geometry on corners are not needed).
Please tell me Otoys plans about that feature.
dtxtreme
Greg wrote:I'm going echo the requests for edge rounding. Edge rounding is **absolutely critical** for both CAD rendering and baking down game assets. Two areas (especially products rendering) that are probably very important to OTOY. The current implementation is not something that works well or is (to be honest) very often usable for professional product rendering. I do a TON of this stuff - Octane is so very good in this area with the huge...glaring...exception of rounded edges. Take a look at V-Ray..or MODO...and bump this up the priority list if possible.
best,
Greg
+1 to Gregs suggestion.
/Fredrik
Hesekiel2517
best,
Greg
+1 a really important feature and unusable at the moment
DrawFun
enricocerica wrote:Tried the last Octane Blender Plugin version, it crashes after starting rendering of a single cube. Tried several times with the same issue, once with windows dump.
Failed devices:
Hi enricocerica,
Could you please give me a bit more details about how to reproduce it, or perhaps a demo scene?
Thanks.
DrawFun
enricocerica
Failed devices:
Hi enricocerica,
Thanks.
DrawFun
Well, it seems that the problem comes from one of my cards on the expander, once removed I don't have the problem anymore, so the issue may be on hardware ...
mykola1985
Hi
1 question to devs. Can we expect a better hair denoising in the next release?
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
