OctaneRender™ Standalone 3.06 TEST 4
mikinik
coilbook, fake shadows - off? + you need to configure scattering settings on environment
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
coilbook
ok after many tries i cannot get caustics. I attached the scene. can anyone help to enable caustics, Thank you
test.zip
(27.26 KiB) Downloaded 223 times
coilbook
mikinik wrote:coilbook, fake shadows - off? + you need to configure scattering settings on environment
hi fake shadows are on. I am not sure how to configure scattering settings on environment. Do i add a scattering medium? Thank you
mojave
mikinik
Thanks for sharing your scene.
Using PMC will help you get better results faster with caustics, however AS is not currently implemented for this kernel.
I've noticed that the noise threshold you were using is too low, so adaptive sampling is hardly or never kicking in, that's why you cannot see any green pixels in your noise layer from the second image you posted (those that are below your noise threshold -noiseless-). If you want to keep using pathtracing, trywith something like 0.01 and you should see an improvement as Octane will concentrate on noisy areas. You may also tweak it during the render without restarting it.
Also, your sphere's material is not using the smooth flag, which you probably want to set to make the sphere surface normals continuous.
Making the number of samples either infinite or a function of the noise level would require significant changes in the way the engine currently works and it's not planned at the moment, sorry.
mikinik
mojave wrote: Also, your sphere's material is not using the smooth flag, which you probably want to set to make the sphere surface normals continuous.
Yes, I overlooked it, my mistake. Thanks for the answer!
coilbook
is it possible in the future to have octane slaves update themselves so we wont have to manually install new version to each PC
and will we see adaptive displacement like blender and vray now have https://youtu.be/dRzzaRvVDng?t=3m35s
Jolbertoquini
coilbook wrote: will we see adaptive displacement like blender and vray now have https://youtu.be/dRzzaRvVDng?t=3m35s
+++1000 i used to use in Iray and mentalray before displacement was adaptive to but ages ago :)
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Goldorak
Since it is done in the geometry at render time it actually could be implemented in the host app above the render engine. We are experimenting with this kind of thing for computed displacement in script/module nodes and will test in 3.07 and finalize by 3.08 if all works.
coilbook
Goldorak wrote:Since it is done in the geometry at render time it actually could be implemented in the host app above the render engine. We are experimenting with this kind of thing for computed displacement in script/module nodes and will test in 3.07 and finalize by 3.08 if all works.
thanks. Also procedural adaptive displacement would be nice. Then it really will be sharp and efficient
Goldorak
With 3.06+ script modules are now production ready, mostly by moving out of luajit, but keeping backwards compatibility with LuaJit FFI, and we are starting to build new nodes that will ship in Octane (along the lines of the built in render jobs). We have already started blocking out new features with displacement and procedurals in mind, and it is working great. With the native module C API coming to nodes, we will be able to speed up performance so that script nodes can perform as well as built in features in Octane for things like sub and adaptive displacement and geometry.
One of the features on the 3.1 roadmap is LLVM based nodes, which can safely embed any user C/C++ node modules compiled to bitcode in ORBX script nodes.
With 3.10 you will also have OSL for even faster eveluation of procedurals on the GPU.
