Version 3.00 - Alpha10.1 (30.04.2016)
papillon
Hello aoktar, any news about the OSX version?
SreckoM wrote:I would like to demo Octane for C4D R17 before purchasing it. Is that possible, I see only demo for R16 version? I made mistake and purchased Blender version before test it thoroughly, and now I can not switch license neither get refund (at least I think as NZ team responds once in month).
You can try R16 version in R17.
papillon wrote:Hello aoktar, any news about the OSX version?
Need some time for that. Sdk is updated and having some new problems on volumetrics.
papillon
Ok, no problem and thanks for the update... In case we don't hear, Happy Holidays to you and all the folks around here!
NVN wrote:HI Aoktar.
Here's a Picture from another User, who has the same Bug.
Its a Plugin or Standalone Bug?
I don't know where to post it?
I'll take a look. It's not a plugin bug if it's a bug, we just read and display the values from SDK. But not important for the time. Check and read info about parallel samples also.
Thanks.
Mikla wrote:Hi;
Is it possible to run v3 alongside with the 2.24.2? What would be the fastest way to go back and forth between v2 and 3?
For ex. i can overwrite 3.0 with 2.0 or inverse of to do run. Also i'm having several C4D versions with different setups to run different versions.
grain
A little TFD test here, god it's nice to be able to render volumes in Octane!
Thanks again Ahmet
https://vimeo.com/149658779
ytsekalo
Hi oaktar. I noticed an issue with the PRIORITY option in the settings with this version. When I set it to low on one of my GPUs it doesn't apply and just goes full load. Could be a bug, not sure...
Screnshot:
As you can see it's set up properly (always worked fine with previous versions) but still full load on the 980 ti
Thanks for your time.
ratata
ytsekalo, thanks for supporting TFD developer by actually buying the product :?
http://www.twitter.com/sandidolsak
6850k|64gb|4 x GTX980ti
