Version 2.24.1-R3 (06.10.2015) - obsolete stable
Hi everybody,
i'll need a few OSX guys to test a new version(2.24). I'm working on to avoid lags geometry updates. Especially for OSX. Thanks.
Also attached a new diagram to show settings. See please.
Render Settings.pdf
(454.12 KiB) Downloaded 279 times
eyeonestudio
We need new for C4D R17..... ;)
eyeonestudio wrote:We need new for C4D R17..... ;)
what happens when do you use R16 version in R17?
eyeonestudio
R16
All Ok....
R17 (octane r16)
Sometimes flies error .Octane.DLL Error.....
cfrank78
Seriously? R17 is, even als alpha and beta, out since MONTHS, and you havent even tryed if there is a difference between R16 and R17? :lol:
Ahmet, Ahmet, Ahmet....
brasco
I think he has been testing it successfully with R17. Check you've deleted all but the R16.cdl64 file as per the install instructions.
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
amtberg
2.24 works in R17 for the most part, but it crashes fairly often. Sent a bug report to Maxon and they confirmed the crash was caused by Octane. I'm attaching the Cinema-generated bug report.
_BugReport.zip
(17.22 KiB) Downloaded 234 times
From user point of view it's very easy to critism. My 24 hours is not enough in one day. Thought that couldn't go to holiday.
Joking aside i have had more important tasks to handle. Plugin is on a transition. I have not so big time to test it deeply in R17.
1- 2.0 -> 3.0 convertions
2- Fixes, improvements for better workflow, better asynchronous updates
3- Convertion for full compatibility to R17 standards. This is delayed operation on my side due plugin works.
4- Adoptation to new things, that's very hard and takes ages.
sdanaher
Ahmet has done a sterling job fixing some nasty bugs and slowness on OSX over the last week or so. Its really improved things.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
sdanaher wrote:Ahmet has done a sterling job fixing some nasty bugs and slowness on OSX over the last week or so. Its really improved things.
Thanks. Here is a test version with latest changes. If someone can checks and gives some feedbacks that would be great. I need to fix this version to progress toward.
There is a different approach to check and send updates in Live Viewer. Hopefully it can decrease lags with high count of polygons. Will make much more lighter to work in viewport.
Also localdb crashes should be fixed for version 2.24.1.
Test Version for Windows 2.24.1(R16)
https://render.otoy.com/customerdownloa ... -test1.rar
Test Version for OSX 2.24.0(R16)
https://render.otoy.com/customerdownloa ... -test4.zip
