I redesigned the loop so wanted to get rid of air bubbles quicker and started to change d5 speed - slowing and speeding it up. So under these pulses phobya broke and I heard some leaking noise. My new uv mayhems coolant has typical smell so I felt it immediately and unplugged the cable out of a PSU immediately.glimpse wrote:Out, that sounds scary..it's good that it was Your bottom rad =) how did You notice?smicha wrote: PS. Yesterday I had a disaster - old phobya died and water started to leak. 2xd5 simply destroyed this shitty radiator. Tomorrow I am receiving a new 560 Hardwarelabs Black Ice rad. On one airplex 480 I still am able to render with temps around 50C on 4 gpus.
P.S. That copper rad is impressive! You still keep same OC at those temps?
A good lesson is that it's much better to have inlet on top of a reservoir and outlet at bottom - air bubbles are out quickly (instead of inlet and outlet both at bottom of a reservoir).
50C is at 50% of d5, 46C is at 100% of d5. With OC 52C on one 480. Crazy stuff. But fans have to be set to 100%.
