OctaneRender™ 2.1 for LightWave™ BETA 2
juanjgon
atnreg wrote:Juanjo, could you please make the displacement to support Octane Procedurals? :)
Now that it needs image texture, using procedurals is real pain as there are 'cracks' in random places because of the 'image' edge. I'm trying to make mountain rock material and it is not working well because of that. Changing the mode (wrap/white/black etc.) does nothing for this.
Try the new "Mirror Tile" option with the LW procedurals in the next release ;)
juanjgon
hdace wrote:Testing in Mac with instance heavy scene (forest). Found same behavior as before in Windows, except worse. It takes two minutes to load all the objects (that's normal), then it takes two minutes to update the GPU (I imagine that could be normal for the first frame although I would hope it would dramatically reduce on further frames), but then It renders the first frame of the sequence as pure black and then claims to be rendering the second frame, hanging. Nothing happens after that. Aborting works without crashing, but I cannot get this to render the sequence at all.
F9 as above, after about four minutes it renders plain black frame.
IPR works okay. Strange.
This problem should be fixed for the next release. The update time was computed as rendering time. Please test it in the next build.
juanjgon
BorisGoreta wrote:Octane newtork is still not remembering settings so I still need to activate it every time I start LW, is there a way I could help to debug this ?
Boris, this problem should be fixed in the next build. Now the plugin should remember the network settings after change them.
atnreg
WOW! You are amazing! When this new version will be available? :)
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
sigmamoon
Sorry but WHY you removed the "brightness scale" and the "dark level" parameters even if you are the color correction shader node....
I know it s a beta2 but we are in production with the 2.0 (considared like a product version) If the Octane team cut some node we never get a retro compatibility with older production
PLEASE JUANJO TELL IT TO THE OCTANE TEAM, "IT S A BAD IDEA TO ERASE SOME OLD FONCTIONS" for compatibility, OCTANE SUFFER OF THIS, AT EACH EVOLUTION. WHEN YOU PRODUCE WITH OCTANE WE LL LIKE TO BE QUIET... grrrrrr :D
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
BorisGoreta
I don't understand this either, they said they didn't have enough "pins" for all functions so they had to get rid of black level which I also use. What "pins" ? Is that some standalone GUI limitation or engine limitation. If it is GUI then let us have it in LW plugin. The reasoning was that only 10 materials in Octane live material library used black level so they thought oh nobody needs that. Who even uses this library, I don't since it doesn't work with plugins.
sigmamoon
a little mess, i think.
More i use octane in my pipeline, less i m reassured... Sounds always in BETA.
We re in real production, and we need to be retro compatible
i don t want blam the Octane krew but he must understand the economic reality of theirs customers.
i know nothing is perfect :(
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
atnreg
sigmamoon wrote:a little mess, i think.
Well, if you want to be sure, then just use the stable version but then you'll miss many great new features. And Juanjo is doing almost miracles with this LW-plugin, of course even he cannot help if the Octane crew decides to do something stupid :)
BorisGoreta
As answered in another thread it is really a limitation of a current Octane GPU architecture and contrast, saturation is more important then black level .
http://render.otoy.com/forum/viewtopic. ... 70#p207522
Return to “Lightwave 3D”
