OctaneRender™ for LightWave™ 2.0 DAILY BUILD
juanjgon
sigmamoon wrote: the octane 2.02 plugin for 3dsMax give us the "NET GPU" information when we use the "OctaneRender Network"
Could we have this information too in the IPR render windows.
thanks
You can see the network information while working with the IPR in the Lightwave status line (the lower text line you have in the Layout interface) ... anyway yes, I should find a site for this information in the IPR window.
sigmamoon
thanks
ho thank you juanjo,
I have not the idea to look into this line (because I must admit this is not academic), but that is enough for me, but in fact it would be better to do it in the same IPR window.
And above all, there are more informations than the 3dsmax plugin like the "net slaves".
juanjo you give us always more of the others plug, thanks a lot :D
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
3dworks
i'm getting a repeatable crash when just resizing the IPR on my mac pro.
steps: open 'mountain.lws' in the displacement demo scenes folder. open IPR window, reposition window as desired (it always appears on my second screen here), then immediately resize to max using right bottom window handle. layout crashes always here at this point.
i will attach whole crash report, but this is the thread crashing:
Thread 21 Crashed:
0   com.apple.CoreGraphics        	0x00007fff93672135 argb32_mark_pixelmask + 14629
1   com.apple.CoreGraphics        	0x00007fff935fd202 argb32_mark + 1264
2   libRIP.A.dylib                	0x00007fff8a34540c RIPLayerBltGlyph + 5542
3   libRIP.A.dylib                	0x00007fff8a343e2b render_glyph_list + 413
4   libRIP.A.dylib                	0x00007fff8a343b0f render_glyphs + 341
5   libRIP.A.dylib                	0x00007fff8a342d4a draw_glyph_bitmaps + 1739
6   libRIP.A.dylib                	0x00007fff8a3421da ripc_DrawGlyphs + 2204
7   com.apple.CoreGraphics        	0x00007fff936c30a3 draw_glyphs + 1449
8   com.apple.CoreGraphics        	0x00007fff93606006 CGContextShowGlyphsWithAdvances + 471
9   com.apple.CoreText            	0x00007fff95853afb CTFontDrawGlyphsWithAdvances + 3643
10  com.apple.CoreText            	0x00007fff95852c16 TRun::DrawGlyphs(CGContext*, CFRange) const + 262
11  com.apple.CoreText            	0x00007fff95852576 TLine::DrawGlyphs(CGContext*) const + 240
12  libtools.11.6.0.dylib         	0x00000001035bf969 DispDrawFTextN + 553
13  libtools.11.6.0.dylib         	0x00000001035d2df4 DispDrawText + 100
14  JJ.LWOctane 11.6              	0x0000000121438f0e IPR_drawPreviewWindow(void*, void*, DrMode) + 702
15  JJ.LWOctane 11.6              	0x0000000121439a14 IPR_statusPreviewWindow(int) + 276
16  JJ.LWOctane 11.6              	0x00000001214342b0 IPR_imageCallback(void*) + 80
17  liboctane.dylib               	0x0000000122b4d9e4 boost::system::system_error::~system_error() + 3310052
18  liboctane.dylib               	0x0000000122f7102a boost::exception_detail::error_info_injector<std::runtime_error>::~error_info_injector() + 1761482
19  liboctane.dylib               	0x0000000122f712da boost::exception_detail::error_info_injector<std::runtime_error>::~error_info_injector() + 1762170
20  liboctane.dylib               	0x000000012294ecd2 boost::system::system_error::~system_error() + 1217746
21  liboctane.dylib               	0x000000012294ed9b boost::system::system_error::~system_error() + 1217947
22  libsystem_pthread.dylib       	0x00007fff8bf27899 _pthread_body + 138
23  libsystem_pthread.dylib       	0x00007fff8bf2772a _pthread_start + 137
24  libsystem_pthread.dylib       	0x00007fff8bf2bfc9 thread_start + 13
apple mac pro 5,1 with 48G RAM, OSX 10.9.4, LW 11.6.3 running with native OSX video drivers, nvidia GTX 780, CUDA 6.0.51.
Layout_2014-07-15-223010_Supercat.crash.zip
(25.3 KiB) Downloaded 299 times
3dworks
also, i don't find ANY instructions on about how to setup octane 2.0 network rendering on mac OSX. or am i missing something?
cheers
markus
3dworks
follow up to my crash report: using the latest nvidia web driver for OSX solves the crash issue!
juanjgon
3dworks wrote:follow up to my crash report: using the latest nvidia web driver for OSX solves the crash issue!
Ok. If you have more problems, please let me know.
About network rendering on OSX, really I never try to setup it. I only have one Mac in the office to compile the plugins. Please, try to follow the setup docs: you need to start the server on the render nodes (using a new Standalone licenses for each node) and use the network panel available in the plugin to configure it.
http://render.otoy.com/manuals/Lightwave3D/?page_id=543
http://render.otoy.com/manuals/Standalo ... ge_id=1248
http://render.otoy.com/manuals/Standalo ... ge_id=1269
If you can't configure the net render, please let me know.
3dworks
i'm getting repeatable crashes when adjusting multiple selected octane lights intensities.
Process:         Layout [12983]
Path:            /Production/*/Layout.app/Contents/MacOS/Layout
Identifier:      com.newtek.LightWave.Layout
Version:         11.6.2 (11.6.2)
Code Type:       X86-64 (Native)
Parent Process:  launchd [204]
Responsible:     Layout [12983]
User ID:         501
Date/Time:       2014-07-16 12:00:40.883 +0200
OS Version:      Mac OS X 10.9.4 (13E28)
Report Version:  11
Anonymous UUID:  FFF76E9D-1495-CBBA-CA8D-A69D7089BEBA
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
abort() called
*** error for object 0x60000a0590e0: Freeing already free'd pointer
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x00007fff8f81d866 __pthread_kill + 10
1   libsystem_pthread.dylib       	0x00007fff8b7de35c pthread_kill + 92
2   libsystem_c.dylib             	0x00007fff92bcab1a abort + 125
3   libsystem_malloc.dylib        	0x00007fff8cb8ebee nanozone_error + 486
4   libsystem_malloc.dylib        	0x00007fff8cb8e1c6 nano_free_definite_size + 114
5   JJ.LWOctane 11.6              	0x000000012220e75a LWOctane_addLight(Octane::ApiNode*, void*, int, int) + 826
6   JJ.LWOctane 11.6              	0x0000000122216bef LWOctane_reloadLight(void*) + 143
7   JJ.LWOctane 11.6              	0x0000000122216c55 LWOctane_reloadSelectedLights() + 53
8   JJ.LWOctane 11.6              	0x00000001221ca759 IPR_update(st_LWMasterAccess const*) + 585
9   JJ.LWOctane 11.6              	0x00000001221ca38f IPR_updateMaster(st_LWMasterAccess const*) + 95
10  JJ.LWOctane 11.6              	0x00000001221c94ec IPR_Event(void*, st_LWMasterAccess const*) + 12
11  com.newtek.LightWave.Layout   	0x000000010005bb0b recordcmd(unsigned short, char*) + 859
12  com.newtek.LightWave.Layout   	0x000000010006a81e ulights(void*, unsigned short) + 14526
13  libtools.11.6.0.dylib         	0x00000001035e04ec ActionDefDispatch + 92
14  libtools.11.6.0.dylib         	0x0000000103603746 CmdEntryFireTag + 214
15  com.newtek.LightWave.Layout   	0x0000000100220a5c lgtsgads(int, int, int, void*) + 3980
16  com.newtek.LightWave.Layout   	0x0000000100232675 panelgads(void*, st_IComponent*, int, void const*) + 11365
17  libtools.11.6.0.dylib         	0x000000010360a5b3 CompClientEvent(st_IComponent*, int, void const*) + 195
18  libtools.11.6.0.dylib         	0x00000001036a5f7a TextEvent(st_NCompText*, int, unsigned short) + 554
19  libtools.11.6.0.dylib         	0x00000001035b7d25 -[LightWaveTextFieldDelegate controlTextDidEndEditing:] + 117
20  com.apple.CoreFoundation      	0x00007fff8eca0e0c __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12
21  com.apple.CoreFoundation      	0x00007fff8eb9482d _CFXNotificationPost + 2893
22  com.apple.Foundation          	0x00007fff8e64b7ba -[NSNotificationCenter postNotificationName:object:userInfo:] + 68
23  com.apple.AppKit              	0x00007fff8cfcd4df -[NSTextField textDidEndEditing:] + 347
24  com.apple.CoreFoundation      	0x00007fff8eca0e0c __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12
25  com.apple.CoreFoundation      	0x00007fff8eb9482d _CFXNotificationPost + 2893
26  com.apple.Foundation          	0x00007fff8e64b7ba -[NSNotificationCenter postNotificationName:object:userInfo:] + 68
27  com.apple.AppKit              	0x00007fff8cfccd58 -[NSTextView(NSSharing) resignFirstResponder] + 638
28  libtools.11.6.0.dylib         	0x00000001035b895e -[LightWaveTextView resignFirstResponder] + 46
29  com.apple.AppKit              	0x00007fff8cea5170 -[NSWindow makeFirstResponder:] + 455
30  libtools.11.6.0.dylib         	0x00000001035bbb36 -[LightWaveUtilityWindow makeFirstResponder:] + 54
31  com.apple.AppKit              	0x00007fff8cfab9c4 -[NSWindow endEditingFor:] + 352
32  libtools.11.6.0.dylib         	0x00000001035b79f1 -[LightWaveTextView insertNewline:] + 129
33  com.apple.AppKit              	0x00007fff8cf9cc2f -[NSResponder doCommandBySelector:] + 71
34  com.apple.AppKit              	0x00007fff8cfca10a -[NSTextView doCommandBySelector:] + 196
35  com.apple.AppKit              	0x00007fff8cf9c151 -[NSKeyBindingManager(NSKeyBindingManager_MultiClients) interpretEventAsCommand:forClient:] + 1392
36  com.apple.AppKit              	0x00007fff8cfbb1c2 -[NSTextInputContext handleEvent:] + 845
37  com.apple.AppKit              	0x00007fff8cf9a9dd -[NSView interpretKeyEvents:] + 180
38  com.apple.AppKit              	0x00007fff8cfbad6d -[NSTextView keyDown:] + 658
39  com.apple.AppKit              	0x00007fff8cf6756b -[NSWindow sendEvent:] + 1843
40  com.apple.AppKit              	0x00007fff8cf08b32 -[NSApplication sendEvent:] + 3395
41  libtools.11.6.0.dylib         	0x00000001035c4800 WManGetInput + 496
42  com.newtek.LightWave.Layout   	0x0000000100155619 domessages(st_lwrender*) + 1577
43  com.newtek.LightWave.Layout   	0x00000001001eb166 main + 1734
44  com.newtek.LightWave.Layout   	0x000000010000fdd8 start + 52
juanjgon
3dworks wrote:i'm getting repeatable crashes when adjusting multiple selected octane lights intensities.
Are you sure that you have only Octane lights selected? ... I am not sure now, but perhaps if you select also Lightwave lights this function could crash.
Anyway I will check this issue ASAP.
3dworks
yes, i double checked. seems to crash with other parameter changes, as well. i tried to check the 'unseen by camera' checkbox with a dozen lights selected. crash result here:
Process:         Layout [28035]
Parent Process:  launchd [202]
Responsible:     Layout [28035]
User ID:         501
Date/Time:       2014-07-17 12:13:38.173 +0200
Report Version:  11
abort() called
*** error for object 0x630000640630: Freeing already free'd pointer
0   libsystem_kernel.dylib        	0x00007fff8f0da866 __pthread_kill + 10
1   libsystem_pthread.dylib       	0x00007fff8b09b35c pthread_kill + 92
2   libsystem_c.dylib             	0x00007fff92487b1a abort + 125
3   libsystem_malloc.dylib        	0x00007fff8c44bbee nanozone_error + 486
4   libsystem_malloc.dylib        	0x00007fff8c44b1c6 nano_free_definite_size + 114
5   JJ.LWOctane 11.6              	0x000000012247a75a LWOctane_addLight(Octane::ApiNode*, void*, int, int) + 826
6   JJ.LWOctane 11.6              	0x0000000122482bef LWOctane_reloadLight(void*) + 143
7   JJ.LWOctane 11.6              	0x0000000122482c55 LWOctane_reloadSelectedLights() + 53
8   JJ.LWOctane 11.6              	0x000000012243e53e LWOctane_octaneL_UIChangeNotify(void*, unsigned int, unsigned int, int) + 254
9   libtools.11.6.0.dylib         	0x00000001036b919c PanelSubEventPropagate + 284
10  libtools.11.6.0.dylib         	0x00000001036b958d ExoCtrlBase_SubValEvent(st_ExoCtrlBasis*, int, int, void*, en_XPEventTypes, void*) + 157
11  libtools.11.6.0.dylib         	0x00000001036bb3a4 ECB_bool_event(st_ExoCtrlBasis*, st_IComponent*, int, void const*) + 132
12  libtools.11.6.0.dylib         	0x000000010360a562 CompClientEvent(st_IComponent*, int, void const*) + 114
13  libtools.11.6.0.dylib         	0x0000000103609df0 Zonis_Down(st_ZonisContext*, MouserInfo*, st_ZoneInfo*) + 96
14  libtools.11.6.0.dylib         	0x00000001035bac29 -[LightWaveView mouseDown:] + 217
15  com.apple.AppKit              	0x00007fff8c826a58 -[NSWindow sendEvent:] + 11296
16  com.apple.AppKit              	0x00007fff8c7c55d4 -[NSApplication sendEvent:] + 2021
17  libtools.11.6.0.dylib         	0x00000001035c4800 WManGetInput + 496
18  com.newtek.LightWave.Layout   	0x0000000100155619 domessages(st_lwrender*) + 1577
19  com.newtek.LightWave.Layout   	0x00000001001eb166 main + 1734
20  com.newtek.LightWave.Layout   	0x000000010000fdd8 start + 52
maybe it's useful to know that i converted all lights in that scene form LW lights (mostly area) to octane lights, previously.
3dworks
please test here. open the scene, activate IPR. select all lights. hit 'p', check and uncheck 'unseen by camera' property a few times. it always crashes here after first or second switch.
Archive.zip
(10.46 KiB) Downloaded 272 times
Return to “Lightwave 3D”
