Version 1.54.2 (Octane Render 1.54) *** 03.06.2014 ***
Kirbyzz,
Full motion blur will come with 2.0, not available on 1.5x. Motion blur option of cameratag could activate camera motion blur on current version. It's used full motion blur on 2.0.
1.5x has only subframe motion blur option as you do. It's a kind videopost effect which uses subframes and mixes them. You can change shutter value of that with camera's shutter time under physical tab. Octanetag couldn't effect because it's not produced by plugin.
There is no way to tweak issues that you mentioned. But, you can speedup the rendering. Don't use full send data option on render settings. Also use much lower maxsamples. Put some octanetag to animated objects, and select "Resend only updated objects" method.
i think you don't see this for incoming 2.0:
http://render.otoy.com/forum/viewtopic.php?f=30&t=39820
Best,
Ahmet
kirbyzz
thanx for your fast answer - ok i optimze it and use this workfow for now.
i´m happy to know that in future it will work :)
best
fabian
lucioing
Ciao Ahmet!
thank you for the update!
I wonder about the window title... Is it right?
Tnx
L.
P.S. I think you should rename the download folder using the version name: "Octane-for-C4D-1_54"
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
close and reopen this dialog. Title stucks with saved layout
lucioing
Thank you!!!
L.
lucioing wrote:Thank you!!!
L.
you're welcome. Hopefully this is last release before 2.0.
lucioing
Here I'm...
Maybe, the pick focus doesn't works on live view...
L.
lucioing wrote:Here I'm...
L.
disable autofocus.
lucioing
L.
disable autofocus.
Hi! Already done...
L.
itaki
Love this release, but can't figure out how to make the full screen viewer open on my 2nd monitor. When I go full screen it just opens right on top of my main screen in a window. Is there a screen selection mode or something?
16 core Mac Pro. 32GB. 2 x GTX 690. C4D.
