Version 1.52.1 (Octane Render 1.52) *** 10.04.2014 ***
Oleg wrote:Glad I could "help" with something x))
yes, thanks. But wire mode has a core problem, it's still here
Weezer
Hi Aoktar. Glad to see the plugin is proceeding nicely, I was wondering, could you give us some idea of your next steps, what with Octane 2.0 coming along? Also, are you going to keep working on this plugin for there foreseeable future?
Thanks for all your work so far!
djart
Hi aoktar,
i did some tests with newest release (1.51)and emission. I found a strange effect using emission and meshno.
As soon i turn from meshno 0 to 1, the emissionpower decreases.
The file is attached for checking.
cheers,
djart
emission_meshno_check.rar
(103 KiB) Downloaded 270 times
miohn
thanks for the fast fix with
disappearing material preview!
regards
Mike
jmarx
I'm having an problem with textures that are cubic mapped not aligning correctly. Up until this version I've had no issues with this.
jmarx wrote:I'm having an problem with textures that are cubic mapped not aligning correctly. Up until this version I've had no issues with this.
pls show me a sample!
fuelnewmedia
Hi aoktar,
with 1.51.0 the standard C4D OpenGL viewport does not update at all when having some more octane materials, even when the octane live viewer is disabled. It's kind of frozen, the only thing that triggers an update is moving or changing the camera. This is sad as animating an octane scene is nearly impossible now...
Best regards,
fuelnewmedia wrote:Hi aoktar,
Best regards,
i don't think that it was different on older versions. Why do you don't refer to liveviewer any kind of animation?
fuelnewmedia
Hi aoktar,
Thanks for your - as always - quick response!
Because LiveViewer does neither show controllers nor axes. Kind of difficult for character animation :)
But I found out what causes the update problem: Octane Lights!
Disabling them does not have any effect, but when you delete them from the scene,
standard viewport is running nicely. Maybe you could implement a killswitch for this?
Best regards,
Best regards,
I have sensed a test version. could you please check for your problems
