Testing Beta 0.87b (SDK 1.20) **updated 04.10**
mattfrodsham
To get this straight: surely it couldn't even be a render instance if it's inside a symmetry object? Or the symmetry wouldn't generate its second half...
I don't know what's in the scene but from eavesdropping on this.. could it rather be a chamfer maker issue?
Windows 8.1 / 4xGTX980 / C4D R18
mate
hey matt, thanks for your tip. Anyways no biggie, I was just trying to figure out why it crashes.
SEHSUCHT Berlin - 22x GTX 780
kirbyzz
i figured out a point in octane plugin 081b with hang up on render end.
i rendered always in 2.000px width - on end he hang up
yesterday i rendered smaller ones with 1800px width and no hang up on the end...behaves normal, so i think it could be that the problem comes with bigger render resolutions?
kirbyzz wrote:i figured out a point in octane plugin 081b with hang up on render end.
how is 0.82?
dinf
I had 3 files in Render Queue this night. No hang-up, no wait for an hour. Everything fine so far. I'll use this for some other times and tell you if it is regular.
Btw, had no time to test it so far: is it possible to render via NetRender, assumed having one Octane render set (standalone + plugin) for each client installed?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
immortalartscom
hey! i found something...
if an animated object is in a hirachy for example the third in depth it gets updated well while rendering. is it in a more complex hirachy a "deeper child", it does not get updated here... please check that! thx
immortal-arts | filmproduction | soundstudio
http://www.immortal-arts.com
kirbyzz
Hi aoktar,
you are right .. rendering 2500px with million of instances
and no hang up on the end with v082 - great :)
Seems to work fine.
I have a question about shadows:
Is it possible to let a light source produce light, but without shadows?
Often i want to light up some areas with a extra light, but i didn´t want to have shadows from that second extra light-source. I tried much, but i always have shadows for every light source - is there a way to say don´t cast shadows for lights?
The other ting is...sometimes Shadows are very very dark.....is the a option to make shadows more transparent,for example only 50% transparency? I cant´t find a option for that.
thanks
fabian
kirbyzz wrote:Hi aoktar,
Seems to work fine.
thanks
fabian
As you know, Octane is a un-biased, physically based renderer. This not has any option like don't cast shadow. Because every point catch light or not. But light shadows in other renderers are fake methods. You can put big light sources to illuminate some dark areas. Big light sources will cast more smooth and more undetectable shadow areas
immortalartscom wrote:hey! i found something...
can you give sample scene?
slepy8
Is this ok, that after uninstalling previous version of plugin and installing ver 0.82 it shows it's 0.7.7 ??
By the way - it still hangs in my render queues... just like before..
