OctaneRender™ for Blender 1.20.2 - 1.6 beta Win [OBSOLETE]
steveps3
(OS) Windows 7(64)
myclay wrote:scatter mode and " as is" works only in preview render mode and there only
~826MB ram is needed for this scene...?
as it seems, mesh lights won´t work while staying in scatter mode;
I have not clearly understood, what you mean in first sentence?.. Can you please explain a little more detailed?..
If you mean that the emission is less if the object is scattered - yes, it is how Octane engine behaves. If you have scattered emitter - try to raise its power.
myclay
Hello Jimstar, thanks for the information about the scatter mode and the Lightning.
the ram usage is different when you go into Viewport shading and use Rendered
viewport shading rendered.png (8.19 KiB) Viewed 4353 times
it will take ~40% less Ram than Pressing the Renderbutton.
But even in the older versions of the plugin there was this hike and I haven´t noticed this before. ^^
Win 7 64 | Geforce GTX570 + GTX260 | i7 3770 | 16GB
myclay wrote:Hello Jimstar, thanks for the information about the scatter mode and the Lightning.
the ram usage is different when you go into Viewport shading and use Rendered,
Thank you, I will check it.
Synthercat
Another bug : Mix node
I had a mat of two colours with turbulance amount and then the mix on the difuse... it worked fine
then I tried to switch the 2 RGB nodes and not mix had no affect it just produced one solid colour
I disconected the turbulance and played with the amount from 0 to 1 with the two different RGBs still attouched to it... still nothing!
Had no time to isolate and reproduce it on new file cause I am on a tight work schedual here!
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
matej
Question:
Will (can) this plugin support any additional texture mapping options, stuff that is not present in the standalone version, like:
- global, object local, camera... auto coordinate spaces for image textures
- rotation, translation transforms for image textures
- multiple UV sets per object (ie. per-texture coordinate assignment)
Octane is extremely lacking in this field compared to other render engines. Hopefully the plugin can do more than the standalone version.
cgmo.net
ROUBAL
Hi Friends ! Just a short message. I would like to be more present, but since the Blender Plugin is available, I have had very few time to test it : I am re-painting my home and my workstation is out of service under plastic sheet.
Anyway, thank you very much for this much expected great tool ! :)
Philippe.
m.arc.in
Hi
I have a problem to run octane blender plugin.
I've downloaded octane srver, and blender octane edition.
Then, I instaled software. First I run octane server, then blender, entered login and password, and nothing hapend.
No errors, nothing...
I double checked login and password.
octane server is switching off after few seconds with no error.
Is it a bug, or I am doing something wrong?
Of course i have activated stand alone version.
I tried on 2 machines
there was about 3 hours passed before second attempt.
I deactivated accounts via web.
can you help me to run octane inside blender?
Marcin
win7 64/core i7 920/32GB RAM/3x GTX 580 3GB 4x GTX 970 4GB/blender 2.79/Rhino 5,0/octane 3
win7 64/core i5-460M/8GB RAM/GTX 460M 1,5GB/blender 2.79/Rhino 5,0/octane 3 (ASUS G73JW)
FooZe
Hi Marcin,
What does the status bar say at the top when you change the viewport to rendered or hit f12?
Can you please try it with a very simple scene, like a cube.
Chris.
Aenima
m.arc.in wrote:Hi
Marcin
Hi Marcin.
This is freshly installed octane server/blender combo? If yes launch octane server from the windows command line and you get an error msg about a missing dll. You can install one of the microsoft redist.
W10 x64 32GB, EVGA GTX960 - EVGA GTX1060 - OSX 10.12.5 - CORE I5 3.4GHz
Return to “Blender”
