Beta 0.5.9 (SDK 1.17 ) (old version)
ashurao
bepeg4d wrote:
ashurao wrote: My problem comes from the specular material.
you need to activate the "fake shadow" option in the proper tab in the attribute editor for letting the sun goes through the specular material, and activate the "alpha shadow" option in the kernel setting ;)
Thanks bepeg4d,
I will try this solution tonight.
Mac Pro 2010 6 cores 3,33 - Mac OS 10.11.6 - 16Go - GTX 780 3Go and GT 640 4Go - Archicad 19 - Cinema 4D R17 Visualise - Octane Render V3
DennisK4
What version of Octane Standalone should I have installed with this beta version of the Cinema 4D plugin? Or does it even matter?
Win 7 x64 | 2 x GTX580 3GB | i7-2600K 3.4GHz | 16GB | Cinema 4D R14 | Nvidia 320.18
Jaybee
Aoktar,
0.5.7 worked fine except for the "combed" histogram and memory leak.
However, no joy at all with 0.5.9 here :( Every time I try to add a material from the LiveDB it crashes C4D, also if I use an octane material I already have locally and apply it to a cube and then try to start a render it crashes C4D.
It will render a cube without a material on though?
Back to 0.5.0 for me...!!
Win 7 x64 | 1 x EVGA GTX680 Classified & 1 x Quadro FX1800 (display) | i7 920 o/c 3.04Ghz | P6TD Deluxe | 24GB | AX860 PSU
DennisK4 wrote:What version of Octane Standalone should I have installed with this beta version of the Cinema 4D plugin? Or does it even matter?
try 1.17 first. if it's ok stay here
AndreaMannori
@aoktar - I did the test discussed in the 0.5 thread... So, I reduced the number of big textures and eliminated one element with dense mesh deformed by a bend deformer...and then everything has gone well. It's not a great deal but at least a good starting point for a good dev ;)
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
indexofrefraction
hm? does the plug use the standalone in some way?
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
not, but for activation is needed
abstrax
aoktar wrote:
indexofrefraction wrote: hm? does the plug use the standalone in some way?
That's not fully correct: You don't have to install the standalone at all. You just need a standalone license. If you never ran the standalone before you installed the plugin, a standalone license dialog will pop up when the plugin tries to authenticate the plugin license. In this dialog you can enter the standalone license.
Marcus
Marcus
ok sorry, but if you have installed older standalone so can give problem? is it right?
abstrax
aoktar wrote:ok sorry, but if you have installed older standalone so can give problem? is it right?
Yes, if you are working on Mac OS and were using Octane standalone, but didn't update the standalone to any of the recent release candidates it may be that you have to de-activate and then re-activate your standalone license. That's because the machine identification has slightly changed to solve a problem with Mac Pros which have two identical Ethernet adapters.
The de-activation and re-activation can be done via the our web interface on http://render.otoy.com/account/octanelive.php
No need to install the standalone version.
