Octane Render 1.022 beta2.2 RC2 available [obsolete]
radiance
SamPage wrote:
radiance wrote:
SamPage wrote:If I try and open an old *.ocs, dismiss the Invalid Scene File Version with OK, then right click on the graph editor, Add->Object->Mesh I get a repeatable crash here.
do you mean all your OBJ imports crash or they only crash after you've tried to open an older OCS file ?
They only crash after trying to open an older OCS.
Sam
ok thanks ;)
Radiance
cgbeige
going over 1024 px in Y works fine for me on OS X. Even with dual GPUs. Doesn't even flicker, let alone show black.
ROUBAL
@Nostromo : Edit : You were right, I had made a confusion with shortcuts on my computer.
See new tests in the post below :
Nostromo
the easiest to check would be to try to load an old ocs. If it goes through, it's RC1 if it says "invalid scene file", it's RC2.
ROUBAL
I have just edited my previous post !
This time I have really tested with 1.022 b2.2 RC2 :
Good news : The vertical strips have disapeared, and Octane now closes correctly.
Bad news : For the memory management, there is still a problem : Instead of 0 MB previously, now Octane displays 4095 MB, but that's still wrong because the actual memory amount of the available cards is 511 MB and 895 MB...
- The device manager and animations panels still display behind the render window.
- Mesh preview kernel node output still disconnected when opening Octane, until you move it.
radiance
ROUBAL wrote:I have just edited my previous post !
great news ;)
the 4096MB video ram bug is a cuda 32bit toolkit bug, we're looking for a workaround...
Radiance
radiance
We will release a last RC3 tomorrow with the remaining issues fixed and hopefully that one can go gold ;)
Radiance
ROUBAL
Hi Radiance,
Great news ! To work so fast, I'm sure that you not only work on Octane, I think that you also drink it ! :lol:
Thank you very much !
andrian
I am getting a little slow down with RC2, it gives me 2.48 samples vs 2.95 samples on beta 2.1 on a simple scene. All manually imported , its a simple interior room with no textures, lit by sun/sky, on GTX 480.
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
radiance
andrian wrote:I am getting a little slow down with RC2, it gives me 2.48 samples vs 2.95 samples on beta 2.1 on a simple scene. All manually imported and textured, its a simple interior room with no textures, lit by sun/sky, on GTX 480.
are you sure everything is configured identically ?
the scene file format is not compatible, so you need to recreate it, and you might have differences.
also keep in mind that this version needs to do a bit more work than 2.1,
it has recursive textures, which is quite a bit of additional/complex code to run through on each ray.
In fact, i was expecting an bigger slowdown, quite happy with the results.
I think some scenes might be a bit slower, and others a bit faster depending on how you configure your mats.
Radiance
