after the download of this new version I get the same problem as the previous one. Octane doesn't even starts. Error message again and again...
Radiance, Marc didn't contacted me... Should I send him an e-mail ?
Octane Render 1.021 beta2.1 released [OBSOLETE]
- mnemonicmethod
hey, it's probably the same reason right ?mnemonicmethod wrote:Hi,
if you click on 'report' does it show you the missing lib glut again ?
I'll have another look, it appears this framework is'nt installed on your 10.5 installation.
Radiance
hey, i opened the new thread here: http://www.refractivesoftware.com/forum ... =14&t=1396mnemonicmethod wrote:Hi,
you need to try something, i've put it in that post.
Radiance
big problem - you can modify the scene as command line renders run. I was letting it run in the background and accidentally moved the scroll wheel over the viewport and it changed the running render. Is there a way to have a quiet Terminal mode (ie: no UI)? It would prevent this type of thing and save cycles spent on screen updates. Just give a typical percentage readout and you're good.
i'll add a start minimized flag, that's quick and easy to add.cgbeige wrote:ya, this is kind of getting in the way now that I'm rendering out all these camera response samples and have the UI popping up over my work every minute. Quiet command (post interrupted by Octane launch) line renders, please.
Radiance
I'm seeing a bug with the Save / Save As command key shortcuts. They just stop working for some reason. I've lost work because I thought command-S was saving the file. Also, Mac programs should show a dot in the close widget when documents have been modified - see attachments. Not urgent but it's helps to make sure that you know you just saved by looking and not seeing the dot.
