OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
That's what OTOY had me do, and it was their only idea, but it didn't work.
OK - I suggest reverting back to 2.25 for the moment until Otoy can work out the issue.
Ken1171
Yes, already did it. Last night I had some ads for a product release that needed rendering, and Octane 2 still does the job. I hope OTOY will resolve this soon. Poser 11's new PBR has been plagued with an incompatibility with nVidia's GeForce drivers that cause Windows to crash into BSOD, and SMS is asking us to disable Branched Path Tracing when GPU rendering, which makes Superfly/Cycles 10X slower, so it's better to render with CPU instead. It's slow in either cases. Neither SMS nor nVidia have resolved this issue in over half a year. Should be easier to fix DRM issues, though.
Following is the Octane 3.01.1 build of the plugin for Windows. There are issues with OSX at the moment, so there is not currently a Mac version of the 3.01.1 build of the plugin.
3.1.1.74
- Compiled with Octane 3.01.1
- Added an "Activation" button to the OctaneLive tab which can be used to deactivate the plugin
- You can now disconnect the Medium from the Environment Medium pin
- Fixed issue where loading certain LiveDb materials would crash the plugin
- The Maximum value of the Power of Image maps for Bump maps is now 5
https://render.otoy.com/customerdownloa ... _Win64.exe
Ken1171
Any chance this could stop the Poser crashing when checking credentials online?
Yes, a chance - can you pls test it?
Ken1171
Still instant crash, darn DRM...
Well, back to Octane 2.
Sorry to hear that Ken - I will get this info back to Otoy.
Ken1171
Much appreciated, Paul. I am really frustrated not being able to use the new version just because of DRM protection. It doesn't seem to be protecting my right to use it.
haruchai
Same issue as Ken1711. I eagerly updated to version 3 at release and have tried every plugin release since and none of them have worked. Standalone installs and works fine. Poser plugin crashes Poser Pro 2014 whenever I try to start the plugin with the authentication error.
Hoping this gets sorted soon.
The Daz Studio plugin crashes Daz as well but I will post in that forum about that one :(
Ken1171
haruchai wrote:Hi,
I have talked with OTOY last Friday, and I think we have figured out what's causing the crashes by examining the crash dump. There might be a solution coming up somewhere this week. In the meanwhile, Octane 2 still works fine with the same authentications credentials.
Return to “Poser”
