OCTANE BENCHMARK: Submit performance scores for your rig!
slepy8
@Roubal - how did you make it?? :)
Are you sure you used pathtracing?
Somebody in previous post had 8 GPUs and got 38ms/sec...
I'm having 12,5Ms/sec with 780Ti and 2 X 660 ...
ROUBAL
Yes, I used pathtracing, sure. But I noticed that there is almost no difference with Direct lighting for this scene.
GTX 580 are good. I have read somewhere on the forum that one Fermi core is equivalent to 3 Kepler cores, so the increase of power with recent cards is not actually huge.
Seekerfinder
BorisGoreta wrote: I wonder if you could stick two Netstor boxes in the main comp and would it work ?
I like the way you think Boris...
Seeker
slepy8
@Roubal - no argument on my side, but Kavorka with single 580 had almost 4,00Ms/s.
No comparison to your time.
You messed some settings bro'
ROUBAL
@slepy8 : Weird, I used the file as it is without moving the camera and I just adjusted to pathtracing... I did the test several times with different combinations of cards, with consistent results... I will try again when I will be on my workstation if I have some time. :roll:
EDIT : OK, I have found the trick : The value I got was with the "Octane Benchmark Trench (CLICK ME)" node enabled as it is in the original file. As it is, I get 48.99 Ms/sec with two GTX 580 enabled for rendering.
BUT, if I connect the node to the render target, I get 8.19 MS/sec with same settings. Direct lighting gives 31.58 Ms/sec.
lightboy
I was using my 660 ti in my system since acquiring Octane last month until it seems Octane pushed it into a progressive failer, where the cuda cores would fail intermittently, then a week later I started to get ogl and screen corruption in modo.
Then last friday I started getting 2d screen corruption as well.
So time for a new video card :)
My wife and I were away on the weekend and I stopped in at a local retailer and picked up a EVGA GTX780 ti classified ( was the only 780ti they had in stock)
WOW this card is a beast! :o
Here is the score with my old GTX660 ti
Benchmark scene:
PT - 2.91 with alpha shadows off
Here is the new evga 780 ti classified out of the box
Default clock rates GPU boasted to 1162 mhz with octane going.
Benchmark scene:
PT - 9.60 with alpha shadows off
PT - 8.44 with alpha shadows on
I then overclocked it to
7200mhz on the memory from the default of 7000mhz
and in octane the gpu boast is at 1262mhz an increase of 100mhz
benchmark scene:
PT - 10.14 with shadow alpha off
PT - 8.89 with shadow alpha on
Temperature never got above 58°C while overclocked.
So far I'm extremely happy with the card.
Keith
Windows 10 | 1950x threadripper |64gb Ram | EVGA GTX1080 ti x3 |
Modo 13 64bit
Lightwave 2018
Nvidia driver 419.67
Octane modo plugin version 4.04.0.145
Octane lightwave plugin version 4.04
smicha
58C? On air? What speed of the fan have you set? If 100% that must be loud...
PolderAnimation
kavorka wrote:you have the same exact card that I linked to?
I think the EVGA one is slower.
I got the exact same card you linked to. When I render to clock speed goes to 1160 mhz.
But I still got 7.6 Ms/s
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
rappet
I looked up the old Benchmark to compare.
18 June 2012:
rappet wrote:Hi,
I am very excited letting my new build doing it's thing with OR. This is the result:
16.72 Ms/sec (4x580, OR 2.57, driver 285.62)
4.18 Ms/sec with just one GPU.
To my surprise with SLI enabled it's just a little difference: 16.53 Ms/sec
greetz,
I am very excited letting my new build doing it's thing with OR (release 1.20).
This is the result:
4x GTX classified: 17.69 Ms/sec
2x GTX classified: 8.85 Ms/sec (turned off 2 to compare)
2x Titans Black: 15.03 Ms/sec
2x Titans + gtx275: 15.79 Ms/sec (turned monitorcard on as well)
Greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
voon
octane_benchmark.ocs ... the one with DL/PT/PMC present as klickable nodes .. so I didn't change anything. Just load and klick on one of the three selections. This is thus WITH alpha shadows.
DL 56.5 Ms/sec
PT 16.3 Ms/sec
PMC 12.0 Ms/sec
Without Alpha shadows:
DL 62.0 Ms/sec
PT 18.6 Ms/sec
PMC 13.4 Ms/sec
2x 780 Ti (MSI Gaming OC cards)
I don't know if there are several different benchmark ocs out there. The one I used says this in the comment node:
Scene made by Francesco Legrenzi (http://www.francescolegrenzi.com), based on Greeble Richard Rosenman idea (http://www.richardrosenman.com).
Fine-tuned by OTOY.
