OctaneRender for DAZ Studio 3.02 [OBSOLETE]
Moderator: BK
jimgale
I reinstalled everything from scratch -> using the new versions 3.02 and 4.9, and after one render (upon loading), the viewport is stuck trying to get/rebuild the scene. Bouncing progress bar with no progress. Always repeatable.
Does it happen on every scene or just one? What does the Octane Log say? Can you post a screenshot of your plugin Preferences panel pls? What version did you update from? Have you read the link in my signature below?
SiliconAya
Right clicked in the main area of the NGE and got:
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\octane.dll" at 0033:0000000012663371, Octane::ApiItem::name()+17 byte(s)
Was a new scene that I hadn't yet saved, just a single G3F and some hair, had only done some morph, switched the kernel to PT, loaded the hair and switched the material from Diffuse to Glossy in the NGE.
Pls let me know if this happens again to you, and I will investigate further.
This thread is now for the STABLE version of the plugin. The TEST release of the plugin can now be obtained from viewtopic.php?f=44&t=55214 - pls subscribe to that thread.
Sorel
Awesome! Attempting to download now, it's being very slow
AlfaseeD
Hi Paul,
I'm having some trouble with the network rendering.
Before this version everything worked pretty smoothly, but right now it seems to not be working.
I'm using the latest ds pluging version 3.02.23 and the slave deamon 3.02.
Any help is really appreciated!
You need to update to the latest version - 3.03.2 (for Standalone and the plugin) - which should resolve this issue.
AlfaseeD
I will do.
Usually for working purpose I prefer to use stable versions, but to be honest I never had any problem so far with any beta version that you release :)
I have merged this STABLE thread into the TEST thread, so this thread is no longer active. Pls subscribe to viewtopic.php?f=44&t=55214 for plugin updates.
Return to “DAZ Studio”
