OctaneRender for Modo 3.03.3 [STABLE]
Tharso
And, How can I remove this black in some images that I render with displacement?
Hi Tharso - to resolve the extra "Shift" property in the Displacement panel, ca you pls delete your Modo901.CFG file and restart Modo - it will hopefully then be removed.
Try reducing your Ray Epsilon.
Tharso
Hi Paul, The ray Epsilon is the default 0.0001, and I could not reduce more here. Am I doing something wrong?
Modo is not displaying smaller numbers, but you can still enter them, and they will be applied to Octane and saved in the Modo scene.
Tharso
I deleted all my configs and shift is still there. I am using modo 902.
Which release of the plugin are you using pls?
Tharso
OctaneRender for Modo901 3.0.1.93
Thanks Tharso. I am unsure why the Displacement Shift is showing for you. May I suggest putting up with it for the moment, and then checking it again in the next release. If it's still an issue then I will look deeper into the problem.
marcus1070
Hi Paul, cheers... i got an issue in the new plugin version(3.0.1.93 in modo 801sp5). Every time i open the viewport with preview switched, modo crashes... and if the viewport is open and i press preview....boom, crash again
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
Have you tried deleting your Modo801.cfg file? Do you have the Render Cache on or off?
Return to “Foundry Modo”
