OctaneRender for Modo 3.03.3 [STABLE]
shift in displacement node don´t work for me. 3.0.1.92
You are right - I will post a fix for this shortly.
Tharso
Thank you
I have refreshed the installers at the top of this thread with:
3.0.1.93
- Fixed issue where the Displacement Mid Level was not accessible on the Displacement node in the Schematic
- Added Windows Modo701 build
- Added Linux and OSX builds
Tharso
I dont understand perfectly the new disp parameters but shift do nothing here yet, the new option medium I set to .5 as zbrush and works good, but shift dont change nothing.
There SHOULDN'T be a "shift" property. If you have one, pls install the latest TEST version of the plugin which renamed this pin to "Height", which is working correctly.
Tharso
There should be a "shift" property. If you have one, pls install the latest TEST version of the plugin which renamed this pin to "Height", which is working correctly.
Yes Paul, there are a height that works to push the geometry here, shift that do nothing and Mid Level that I set to 0.5 like zbrush disp.
I dont know why shift do nothing here. Is it normal?
I don't see a Shift on my version of the plugin. Are you able to post a screenshot of the Displacement panel showing it pls? Which version number is your plugin showing?
Tharso
funk
Tharso, does this happen in new scenes? Or just older ones you load?
Tharso
funk wrote:Tharso, does this happen in new scenes? Or just older ones you load?
i didnt tried with new scene, just old scenes.
Return to “Foundry Modo”
